moto trials rules Posted October 1, 2006 Report Share Posted October 1, 2006 i noticed there are a new pair of pards on tarty bikes called rock pads (blue) does anyone know of these or what they r like?i need some new ones and wernt sure weather these r worth it? Quote Link to comment Share on other sites More sharing options...
matt! Posted October 1, 2006 Report Share Posted October 1, 2006 yea i have heard postiove things about thses pads, but not many people have ran them, seen as tartybike have only recently had there first batch of them. Quote Link to comment Share on other sites More sharing options...
Stan Shaw Posted October 1, 2006 Report Share Posted October 1, 2006 Ive had a set for 2/3 weeks and they are pretty much the best pad ive ever used. Wear rate seems good aswell. Also work alot better than Plaz in the rain. Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted October 1, 2006 Report Share Posted October 1, 2006 Ive had a set for 2/3 weeks and they are pretty much the best pad ive ever used. Wear rate seems good aswell. Also work alot better than Plaz in the rain.Are they better than coust pads then? Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted October 1, 2006 Report Share Posted October 1, 2006 Ive had a set for 2/3 weeks and they are pretty much the best pad ive ever used. Wear rate seems good aswell. Also work alot better than Plaz in the rain.Most pads are better than Plaz in the rain?Or are they better in dry aswell.Mat Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted October 1, 2006 Report Share Posted October 1, 2006 Do they work on smooth rims? Quote Link to comment Share on other sites More sharing options...
manxrider Posted October 1, 2006 Report Share Posted October 1, 2006 I'll be ordering some tomorrow hopefully. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted October 1, 2006 Report Share Posted October 1, 2006 £18 for a set...umm may get a set when i order more stuff!!Stan is Tartymake these again or they off a UK manafacutre Quote Link to comment Share on other sites More sharing options...
moto trials rules Posted October 1, 2006 Author Report Share Posted October 1, 2006 who ever it was that sed they have had them for three weeks (sorry cant be bothered to go back and look )what rim are you running?cause i have an onza ronnie wit grind which ruined some new echo pads within 3 or 4 evening rides so i would like to try them if they last long enough? Quote Link to comment Share on other sites More sharing options...
GTF Posted October 1, 2006 Report Share Posted October 1, 2006 do they work well on smooth rims? Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted October 1, 2006 Report Share Posted October 1, 2006 Tartybikes.co.ukDescription - NEW super-high performance brake pads courtesy of new brand Rock Pads.- Extensive testing carried out with some of the World's top riders to ensure arguably the best performing pads we've used! - 8mm of pad material.- Aggressive bite/sound with bucket loads of power.- Individually hand made to ensure the best quality products.- Great performance in both the wet and dry makes them an ideal choice for winter.Recommended UseSharp light grind for dry weather, sharp slightly deeper grind for wet weather Quote Link to comment Share on other sites More sharing options...
max-t Posted October 1, 2006 Report Share Posted October 1, 2006 (edited) it was stan shaw who said that and he is running a onza rim i think.max....Edit: i see he is posting now so ill leev him to it :$ Edited October 1, 2006 by max-t Quote Link to comment Share on other sites More sharing options...
Stan Shaw Posted October 1, 2006 Report Share Posted October 1, 2006 They are better than Plaz in the dry too, not by loads but it is hard to beat Plaz. Im running a Tryall rim (which is the same as Hog btw) with a light and sharp grind. As for smooth rims, of course they will work on smooth rims, just how good i aint sure They will definately last longer than Echo pads. Echo pads arnt really great with a grind, in terms of wear rate.Danny Butler and Marco Hosel also use the pads as far as im aware. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 1, 2006 Report Share Posted October 1, 2006 Can the material be bought alone for use with CNC backing's?If so, where from? Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted October 2, 2006 Report Share Posted October 2, 2006 Probs not so you'll need to boil them in waheter for 5 mins to get the glue to go soft anf pull them apart then cut them down and fit them. Quote Link to comment Share on other sites More sharing options...
trialsalot Posted October 2, 2006 Report Share Posted October 2, 2006 i ordered a set of these last week an after having bounce on stans bike i think they bite more than my cousts on cnc backings.i've got a fresh grind all ready to go.with the cousts you have to have a beast of a grind most of the time and i dont like vibration white finger from my grinder 8mm of pad material too!!for £18....bargain i think!get buying guys.....good enough for stan an butler.....easily good enough for a meer mortal like mecraig Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted October 2, 2006 Report Share Posted October 2, 2006 Well my rder went it today, with a new maggy lever should be here for fitting tomorrow, ill see how things go Quote Link to comment Share on other sites More sharing options...
