The lemonade man Posted September 30, 2006 Report Share Posted September 30, 2006 Can anyone explain how exactly I change a magura crossover cable? I just snapped mine and need to know if I need new fittings or I can use my old ones. Also is it a hard job?Cheers Quote Link to comment Share on other sites More sharing options...
Joey B Posted September 30, 2006 Report Share Posted September 30, 2006 (edited) It's not tooo bigger job. If its just the standard magura hosing then yes you can use the fittings but from personal experience they are a right bitch to push into the new hosing. You can get replacement hosing from Cleanbikes (The hosing is listed under "Brake Spares") for £2.50 a metre or get the red braided hose which i MUCH stronger for only £5.00 a metre. All you have to do is puch the magura pipe nipples into each end of the hose, screw to the callipers and re-bleed. Job done Edited September 30, 2006 by fugigas Quote Link to comment Share on other sites More sharing options...
The lemonade man Posted September 30, 2006 Author Report Share Posted September 30, 2006 Oh wicked, thanks. Does anybody know about cleanbikes delivery, how long is it?Thanks Oh and is it worth buying some braided hosing for it? Does this fit in the same way? Quote Link to comment Share on other sites More sharing options...
