steve@banbury-trials Posted September 28, 2006 Report Share Posted September 28, 2006 how do i go about screwing a fixed sprocket to my tensile cranks? do i need to use a chain wip or something?steve Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted September 28, 2006 Report Share Posted September 28, 2006 Screwing a fixed cog on?Have crank in hand, place cog over and spin it lol? Then when you put it on the bike as you pedal it'll tighten itself Quote Link to comment Share on other sites More sharing options...
darrenhopper Posted September 28, 2006 Report Share Posted September 28, 2006 (edited) Hi-you mate, With your drive side crank off the bike, screw on, by hand, the fixed cog. You won't need to use a chain whip because the cog tightens in the same direction as you pedal... All that means is that the cog will be good & tight after the first time you stamp on the pedals (bike fully assembled... cranks tight... wheel in place & chain fitted).If you're using a bash ring be sure to put that on first.Hope this helps.Man it's crappy when someone beats you to it! Edited September 28, 2006 by darrenhopper Quote Link to comment Share on other sites More sharing options...
