Clarky Posted September 23, 2006 Report Share Posted September 23, 2006 (edited) When is this frame availible?escription- Updated for 2007, the ZOO! Pitbull frame made famous be Neil Tunnicliffe now has two great geometry options!- New concept for trials... 116mm spaced dropouts means a single speed rear hub can be used with snail cams taking care of the chain tension; really simple and minimalist! This requires an 18:15 gear ratio to be used, other gear ratios can be fitted with the use of a half link.- Externally butted head tube has gussets at the top and down tubes, to help strengthen the head tube area of the frame.- CNC Machined one-piece BB shell and chainstay yoke for increased pedalling response.- Built in brake booster creates a stiff and powerful rear brake.- Chunky down tube increases weld area at the head and down tubes, increasing stifness and strength.- Brushed aluminium and lacquered finish resists scratches and looks classy!- Weight: 2.133kg/4.704lbsGeometry (with Echo Urban fork)Wheelbase: Short 1065mm, Long 1100mmChainstay Length: 377mmBB Rise: Short 10mm, Long 25mmHead Angle: 72 degreesCentre of BB shell to top centre of head tube: Short 665mm (26.25"), Long 680mm (26.75") Off Tartybikes website Edited September 23, 2006 by JASON CLARK Quote Link to comment Share on other sites More sharing options...
_skj0lsvik_ Posted September 23, 2006 Report Share Posted September 23, 2006 this is almost the shizzle Quote Link to comment Share on other sites More sharing options...
Guest Posted September 23, 2006 Report Share Posted September 23, 2006 (edited) Price: £299.00 | Stock: (Arriving mid November) It's on tartybikes. Have you e-mailed them for a specific date? Might be a good idea rather than asking a bunch of random people on a forum.... Edited September 23, 2006 by jake1516 Quote Link to comment Share on other sites More sharing options...
Clarky Posted September 23, 2006 Author Report Share Posted September 23, 2006 right i didnt see the "stock arriving early november, yes i have emailed them but waiting till monday for a reply, so i thought if people on forum would know any better. Quote Link to comment Share on other sites More sharing options...
tipus Posted September 23, 2006 Report Share Posted September 23, 2006 yeaaahhh! Loved the 05 geo, and this one is the same, I think...I'm having this in november, aww! Quote Link to comment Share on other sites More sharing options...
_skj0lsvik_ Posted September 23, 2006 Report Share Posted September 23, 2006 yeaaahhh! Loved the 05 geo, and this one is the same, I think...I'm having this in november, aww!? You going to get a new 26" frame? Quote Link to comment Share on other sites More sharing options...
Stan Shaw Posted September 23, 2006 Report Share Posted September 23, 2006 Im guessing you want the 135mm spaced rear end one? I "think" they will be in before mid november.. Quote Link to comment Share on other sites More sharing options...
tipus Posted September 24, 2006 Report Share Posted September 24, 2006 Im guessing you want the 135mm spaced rear end one? I "think" they will be in before mid november.. yeah arrrr, so you'r getting it before release date i guess? Quote Link to comment Share on other sites More sharing options...
Clarky Posted September 24, 2006 Author Report Share Posted September 24, 2006 Whats the difference between the 116mm and the 135mm versions, i will be running chris king hd hub on it and 18:15 ratio Quote Link to comment Share on other sites More sharing options...
SomeoneNew Posted September 24, 2006 Report Share Posted September 24, 2006 116mm one are single speed with horizontal dropouts, you have to run a mod hub with these. 135mm is your bog standard mtb size etc Quote Link to comment Share on other sites More sharing options...
Clarky Posted September 24, 2006 Author Report Share Posted September 24, 2006 (edited) 116mm one are single speed with horizontal dropouts, you have to run a mod hub with these. 135mm is your bog standard mtb size etcso is 135 vertical like usual stock frames, mech hanger e.t.c Edited September 24, 2006 by JASON CLARK Quote Link to comment Share on other sites More sharing options...
SomeoneNew Posted September 24, 2006 Report Share Posted September 24, 2006 yep the 135mm has mech hanger etc like the usual so it'll be exactly like the 06 bar the geometry Quote Link to comment Share on other sites More sharing options...
Clarky Posted September 24, 2006 Author Report Share Posted September 24, 2006 kool thats what i like to hear Quote Link to comment Share on other sites More sharing options...
