powerz Posted September 20, 2006 Report Share Posted September 20, 2006 Hi,I have a magura louise disc on the front of my G.U but the lever pulls right upto the grips & even if i tighten the brake right up so the pads rub on the disc it still pulls right into the grips BUT if i pump the brake around 10 times it then seems to work O.Kwhy is this and how can i fix the prob.Thanks for help Quote Link to comment Share on other sites More sharing options...
Lee Cable Posted September 20, 2006 Report Share Posted September 20, 2006 Hi,I have a magura louise disc on the front of my G.U but the lever pulls right upto the grips & even if i tighten the brake right up so the pads rub on the disc it still pulls right into the grips BUT if i pump the brake around 10 times it then seems to work O.Kwhy is this and how can i fix the prob.Thanks for help Bleed it, with water, get all the air out, i had the same problem with my magura clara. If it doesnt work, keep bleeding it. Quote Link to comment Share on other sites More sharing options...
powerz Posted September 20, 2006 Author Report Share Posted September 20, 2006 Bleed it, with water, get all the air out, i had the same problem with my magura clara. If it doesnt work, keep bleeding it.O.K i will get it re-bled then.Thanks for advice Is there and advantage to using water??? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted September 20, 2006 Report Share Posted September 20, 2006 Possibility for water to boil down a long downhill?I know this isn't downhilling, but my Avid BB7 has become really hot during some places and its hot enough to start losing power.But whatever, water is thinner than mineral oil and will give it a lighter feel.I'd stick to mineral oil though to be honest. Quote Link to comment Share on other sites More sharing options...
powerz Posted September 20, 2006 Author Report Share Posted September 20, 2006 So the thinner the liquid the lighter the feel then.what about using DOT 4 ebc brake fluid,my dad uses it for his quad, would it be better than using water Quote Link to comment Share on other sites More sharing options...
mission man Posted September 20, 2006 Report Share Posted September 20, 2006 (edited) i was going to use dot 4 on my magura louise when it needs a bleed but people have told me not to as it wrecks the seals straight away. dont know if anyone can confirm this. but people also say that water wrecks the seals in the magura 33's but mine havent yet and ive bin running water for about 8 months. so try it prob be ok, if anything starts to happen with it start using mineral oil again.mission man Edited September 20, 2006 by mission man Quote Link to comment Share on other sites More sharing options...
The Duck Posted September 20, 2006 Report Share Posted September 20, 2006 Bleed it, with water, get all the air out, i had the same problem with my magura clara. If it doesnt work, keep bleeding it. Worked for my louise! But I think he means water and Anti-freeze, so it doesn't go icey in cold weather.Gurd luck! Quote Link to comment Share on other sites More sharing options...
powerz Posted September 20, 2006 Author Report Share Posted September 20, 2006 O.K thanks guys. i think i'l probly use mineral oil to be on the safe side.I'm glad it is probly just air in it and not something abit more pricy Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted September 20, 2006 Report Share Posted September 20, 2006 you might of blown a seal, i did with mine on my dirt jumper.didnt know for years by then the brake was fully dead Quote Link to comment Share on other sites More sharing options...
powerz Posted September 20, 2006 Author Report Share Posted September 20, 2006 you might of blown a seal, i did with mine on my dirt jumper.didnt know for years by then the brake was fully dead Dont say that,that will not be good I might take it down halfords and get them to give the brake a service.More Money Quote Link to comment Share on other sites More sharing options...
tomtrials Posted September 20, 2006 Report Share Posted September 20, 2006 Dont say that,that will not be good I might take it down halfords and get them to give the brake a service.More Money Lol funny post. Best bet is to have a go yourself go on google and search how to bleed the brake like the other guys have said it is alot better to bleed with water and it is alot less messy. the only really downside is that water will freeze in cold temperatures. Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted September 20, 2006 Report Share Posted September 20, 2006 the only really downside is that water will freeze in cold temperatures. ANTIFREZE!!!?? my mate runs it , works briliantly Quote Link to comment Share on other sites More sharing options...
poopipe Posted September 20, 2006 Report Share Posted September 20, 2006 ANTIFREZE!!!?? my mate runs it , works briliantly just cos nobody else has said it in big lettersDONT PUT DOT4 IN A BRAKE THATS DESIGNED FOR MINERAL OIL BECAUSE YOUR BRAKE WILL DIE Quote Link to comment Share on other sites More sharing options...
powerz Posted September 22, 2006 Author Report Share Posted September 22, 2006 (edited) Went to re-bleed my brake yesterday with water & antifreez and also changed the hose as it had a bad kink in it but as i tightened the screw up on the caliper that holds the hose the screw snaped half in the caliper so i ordered a new front brake yesterday and it turned up today so iv'e been riding allday Thanks for help problem kinda solved now Edited September 22, 2006 by powerz Quote Link to comment Share on other sites More sharing options...
tom 20 Posted September 22, 2006 Report Share Posted September 22, 2006 nice1 m8..bak 2 buiseness Quote Link to comment Share on other sites More sharing options...
lawrence osborn Posted September 22, 2006 Report Share Posted September 22, 2006 Ive cracked a magura at the bleed screw from tightening it to much :$ also your disk does get amazingly hot, one day me and a few mates was out riding and there was this twat watching us from the bottom of this big hill shouting questions at us, so we decided to go and see what he wanted and my mate went down the hill fast with his disk brake on, when we got to him my mate said to this twat guy push my disk over a bit mate, and this guy push his disk and it burned his fingers Quote Link to comment Share on other sites More sharing options...
