Used Frame
Frost
Through a series of events and interacting with other forums I got in touch with Jeremy VanSchoonhoven who to the best of my knowledge is a pro trials rider in the USA, he was selling his Adamant A1 frame with only just a couple weeks of use on it. There are some scratches but from the pictures it seems structurally sound. I guess my thoughts are given his level of riding does it seem worth wild to purchase this frame from him, and second even if you were to purchase a used frame and regardless if it came with cracks or you later damaged it (I know it depends on what sort of damage was done) wouldn't it still be covered under some sort of warranty?
Thanks
I'm pretty sure it would still have the warrenty..
Unless it doesn't cover riding it? :P
If you do snap/crack it, I think you'll have to send it back to the original owner, so he can send it to the manufacturer with reciepts etc... :ermm:
Edited by Dan6061
that sounds right
warranties usually aren't transferable so unless you could persuade him to take the frame and send it back for you there'd not be much you could do.
