Callum Trialsin Posted September 17, 2006 Report Share Posted September 17, 2006 hi,just bought a computer off here but i need the internet upstairs, so to do this ill need like a wire running up stairs which isnt a problem (parents dont want me to waste money on wireless for some reason )what fittings do i need and like other stuff?any help would be well helpfulthanksCallum Quote Link to comment Share on other sites More sharing options...
anzo Posted September 17, 2006 Report Share Posted September 17, 2006 Ethernet Card for your PC, costs around £10. A network cable, usually about £15 or so for a Belkin one (Highly recommended, lifetime warrenty) and a second ethernet card for your hosting pc if it doesnt have one already.Basically install both ethernet cards, DO NOT plug the cable in straight away though, windows should pick the card up and install it automatically...in an ideal world. Then use the Networking Wizard to set up your network.Fun the wizard on the HOSTING pc first (one downstairs) and add the PC upstairs as a guest user.That should work...however, as its a computer and using windows, it probably wont be that easy Quote Link to comment Share on other sites More sharing options...
tomturd Posted September 17, 2006 Report Share Posted September 17, 2006 Ethernet Card for your PC, costs around £10. A network cable, usually about £15 or so for a Belkin one (Highly recommended, lifetime warrenty) and a second ethernet card for your hosting pc if it doesnt have one already.Basically install both ethernet cards, DO NOT plug the cable in straight away though, windows should pick the card up and install it automatically...in an ideal world. Then use the Networking Wizard to set up your network.Fun the wizard on the HOSTING pc first (one downstairs) and add the PC upstairs as a guest user.That should work...however, as its a computer and using windows, it probably wont be that easy Yep that way works, but only when the computer with the internet attached to it is turned on.Look at the back of your broadband modem, there might be a spare ethernet port. In that case you just need a spare ethernet/network card (same thing) for your new computer, and a network cable between the 2. That way it should work even with only your computer turned on. Quote Link to comment Share on other sites More sharing options...
Danny Posted September 17, 2006 Report Share Posted September 17, 2006 If your modem has an Ethernet connection (Not USB) get yourself a cheap £15-20 router. Will do the job much better than sharing the connection with windows. Quote Link to comment Share on other sites More sharing options...
Extreme_biker0 Posted September 17, 2006 Report Share Posted September 17, 2006 Cut the cable that connects the modem to the computer. You should find that actually there are 2 separate cables inside it. You can use one of them (extend it if you need, and put a usb pug on the end) to connect it to the other computer.Viola. Quote Link to comment Share on other sites More sharing options...
Danny Posted September 17, 2006 Report Share Posted September 17, 2006 Cut the cable that connects the modem to the computer. You should find that actually there are 2 separate cables inside it. You can use one of them (extend it if you need, and put a usb pug on the end) to connect it to the other computer.Viola.I really hope your joking Quote Link to comment Share on other sites More sharing options...
Krisboats Posted September 17, 2006 Report Share Posted September 17, 2006 I really hope your joking ha ha Quote Link to comment Share on other sites More sharing options...
Extreme_biker0 Posted September 17, 2006 Report Share Posted September 17, 2006 No. Every time this question is asked people just give the same answers over and over.People obviously continue asking because they want alternative methods Quote Link to comment Share on other sites More sharing options...
