dave85 Posted September 17, 2006 Report Share Posted September 17, 2006 It wouldnt clamp at all. Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted September 17, 2006 Report Share Posted September 17, 2006 You could just wrap shed loads of electrical tape on there, might work, might not, worth a try i suppose. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted September 17, 2006 Report Share Posted September 17, 2006 which bit is the cylinder washer btw the rubber bit inside the lever? Quote Link to comment Share on other sites More sharing options...
King C Posted September 17, 2006 Report Share Posted September 17, 2006 The electrical tape idea does work but its not as good as the actual washer. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted September 17, 2006 Report Share Posted September 17, 2006 which bit is the cylinder washer btw the rubber bit inside the lever? Plastic bit that goes on the cylinder, and helps clamp it in the mounts. I use electrical tape on one side of my Magura, works well. Quote Link to comment Share on other sites More sharing options...
