matt! Posted September 17, 2006 Report Share Posted September 17, 2006 (edited) hi guys, well ive just got my highest sidehop 42" its good for me but i no people can do that in theeir sleep! i have found that the lower the presure the easy it is to sidehop, this make sense realy, has anyone else found that the lower the presure is the better they ride, this is mainly aimd at the rear tyre pressure but i also find that the lower the front tyre pressure the easyr it is to sidehop, i duno how it works though i little less weight maybe? anyone else found that lower pressure helps them to ride or has no effect on their riding at all? dose your riding style help you get along with low pressure too? also added a pic of my!side hop! this one is only 41" though! i didnt get a picture of my 42" here: sorry about the quality it is a print screen of a the clip!cheers matt! Edited September 17, 2006 by matt! Quote Link to comment Share on other sites More sharing options...
trials_noob Posted September 17, 2006 Report Share Posted September 17, 2006 I am still learning the basics in trials but lower pressure does help. It makes the tyre more 'bouncy' therefore there is a bigger impact from preloading. Having lower pressure will make a very very minuscule change to the weight over high pressure. Hope that helps Quote Link to comment Share on other sites More sharing options...
matt! Posted September 17, 2006 Author Report Share Posted September 17, 2006 yea having a diffrent tyre compound will help aswel! Quote Link to comment Share on other sites More sharing options...
tom 20 Posted September 17, 2006 Report Share Posted September 17, 2006 i think findin the right tyre pressure can be a right f**ker..it all goes wrong wen u keep rimming it constantly annoyin and it puts me off.i go home nd pump the blugy thing up agen Quote Link to comment Share on other sites More sharing options...
stetpro Posted September 18, 2006 Report Share Posted September 18, 2006 lower tyre pressure gives you a better preload but don't have it to low. to find the right pressure take a pump out with you have about 15psi in and keep letting little amounts of air out until you have the perfect pressure. obviously pump it back up if you let to much out. personally i run 10-13psi and that is right for me. give it a try Quote Link to comment Share on other sites More sharing options...
matt! Posted September 18, 2006 Author Report Share Posted September 18, 2006 lower tyre pressure gives you a better preload but don't have it to low. to find the right pressure take a pump out with you have about 15psi in and keep letting little amounts of air out until you have the perfect pressure. obviously pump it back up if you let to much out. personally i run 10-13psi and that is right for me. give it a tryyea this is what i do man! thanks for the edvice thoguh, hope other people can learn from that! Quote Link to comment Share on other sites More sharing options...
Ben Beckett Posted September 18, 2006 Report Share Posted September 18, 2006 i normally have my tyre pressure hard all the time,cuz i take a pup out with me i'm going to start letting my tyres down so they are nice and soft to see if i can gain an extra few inches in my sidehops, ill pump em back up wen i'm not side hopping. Quote Link to comment Share on other sites More sharing options...
matt! Posted September 18, 2006 Author Report Share Posted September 18, 2006 i normally have my tyre pressure hard all the time,cuz i take a pup out with me i'm going to start letting my tyres down so they are nice and soft to see if i can gain an extra few inches in my sidehops, ill pump em back up wen i'm not side hopping. yea this is what i do alot of the time, realy helps! i always pump my tyre back up when doing a gap etc! Quote Link to comment Share on other sites More sharing options...
