Crashpad Posted September 16, 2006 Report Share Posted September 16, 2006 Can anyone tell me if a set of Middleburn superpro trials cranks will fit on a Pashley 26Ghz??Is there enough clearance above the chainstay with 16t chainring?Cheers Quote Link to comment Share on other sites More sharing options...
Conor the basher. Posted September 16, 2006 Report Share Posted September 16, 2006 yer they will.22 tooth middleburns fit so will a 16.make sure you have a wide bottom bracket though Quote Link to comment Share on other sites More sharing options...
threesixty Posted September 16, 2006 Report Share Posted September 16, 2006 Click Me that should help with the bb size. not to sure about clearance but judging from the beast of a bb you need shouldn't be a problem Quote Link to comment Share on other sites More sharing options...
Ali C Posted September 16, 2006 Report Share Posted September 16, 2006 yer they will.22 tooth middleburns fit so will a 16.make sure you have a wide bottom bracket thoughno no noooooo.....you dont need a wide bb, you might be able to get away with a 113mm!!!The narrower the bb the lighter it is and the stronger it is, also the bearings will last longer.you almost definatley wont need any bigger than a 118mm axle Quote Link to comment Share on other sites More sharing options...
