threesixty Posted September 12, 2006 Report Share Posted September 12, 2006 wondering if anyone knows what the geo for this frame is as i cant seem to find it anywheremuchas gracia Quote Link to comment Share on other sites More sharing options...
Billy Posted September 12, 2006 Report Share Posted September 12, 2006 1020 wb with straight forksZero BB riseChainstays, roughly 375. Im using a DX32 with a Hansventure 2.4, and theres about 5mm clearance with the seat tube. Quote Link to comment Share on other sites More sharing options...
threesixty Posted September 12, 2006 Author Report Share Posted September 12, 2006 1020 wb with straight forksZero BB riseChainstays, roughly 375. Im using a DX32 with a Hansventure 2.4, and theres about 5mm clearance with the seat tube.genious, thanks alot for that mate Quote Link to comment Share on other sites More sharing options...
Krisboats Posted September 12, 2006 Report Share Posted September 12, 2006 1020 wb with straight forksZero BB riseChainstays, roughly 375. Im using a DX32 with a Hansventure 2.4, and theres about 5mm clearance with the seat tube.The stays are 380 aren't they? Either way the wheel base should be around 1040 even my old straight blade club roost forks made the wheelbase was around 1035. You can manage a 2.5 michelin comp 24 (same as a maxxis minion) in the rear with enough clearance for a buckle on both a planet-x BMF rim and an onza ronnie. Quote Link to comment Share on other sites More sharing options...
Billy Posted September 12, 2006 Report Share Posted September 12, 2006 The stays are 380 aren't they? Either way the wheel base should be around 1040 even my old straight blade club roost forks made the wheelbase was around 1035. You can manage a 2.5 michelin comp 24 (same as a maxxis minion) in the rear with enough clearance for a buckle on both a planet-x BMF rim and an onza ronnie.I'm not too sure. I figured 375 sounded about right, because I can only just fit the Hansventure in, and I got 1020 when I measured Quote Link to comment Share on other sites More sharing options...
