Mavic Rims
GTF
i had a d521 on my zoo 06 pitbull when i 1st bought it, but i found that it was too thin and the brakes was extremely annoying to set up (N) , they was as far in as they could go, and you would need new pads (no wear)... i'd say that 38mm rims are the best for these frames due to them not being too wide.the wider ones your feet tend to sometimes hit the brake (N) .....
they can be used but it isnt the best rim too use...........go for a wider rim mate (Y)
Or run a pad bodge (screw an extra set of backings on to your pads, so the pads are an extra 8mm or so in towards the rim
Will hunt for pics and edit for you....
IPB Image
IPB Image
Alternatively, there's the offset maggie mounts:
IPB Image
Something like that should do the trick if you don't want to run a wider rim
(sorry the pics slightly too large really, but resizing takes a little effort and that's straight from another thread, so should be ok!)
Edited by rideside
