Crank Question?
t33zr
I can't remember off-hand what the Try-All cranks are like, but could you not just run something like the Echo bash? They're machined down so they're only 4mm at the base (or were, at least?), so you'd only loose a bit of threads from that. If there's a bit of over-hang it's not the end of the world, just so long as you've got a decent amount of threads under the freewheel body.
