What Gear Ratio
kid creole
hi just wondering what gear ratio every one uses on stocks? i use 18 to 14 but i hear people saying they use 18 to 16 surely this is to light or is it just me :unsure:
this probaly wont help because i ride mod(20")......I run 12 rear 18 front (Y)
fells lush :lol:(Y)
^feels^
Edited by liam_thornton
Generally the most common gear ratio is 22:18, but sometimes can be a little bit to hard depending on your riding style, some people use 22:19 although if you are in to saveing weight you can have practcally the same ratio as 22:18 in 18:15 which is very slightly easyer, this is becomeing alot more common nower days and seems to becomeing the stander on most good trials bikes. finally i think its 16:12 which is used by people who run a midleburn super pro trials guard, again saveing weight and being able to have a easy enough gear to ride trials.
Will
Stock Advice, not Mod.
I run 20/18. Team mate Dave runs 22/21. I know a couple of riders running 16/16 and they can get up/gap bigger stuff than me.
I'm not convinced that when it comes to stationary tricks the gear ratio makes any difference.
It makes a difference for run ups and rolling tricks. I find with my slightly stiffer gear, I can ride up to something and kick straight on to it without having to use a tap. In certain scenarios that's useful.
I tried 22/19 once and hated it. It just made everything hard work.
For me, when I have to ride demos for two solid days, the looser a gear I can get away with the better as it uses less energy. I'm considering moving to 20/20 because of this.
How's this for crazy - at one point Dave was running (without realising) 20/21, i.e UNDER a 1:1 ratio and he we was still doing static 8 foot gaps.
