liam_thornton Posted September 8, 2006 Report Share Posted September 8, 2006 hii want to get my white industries front freewheel of of my cranks but i cant seem to get it off, my dad cant even get it off, is there a special way of getting it ofany suggestions? Quote Link to comment Share on other sites More sharing options...
Ben Beckett Posted September 8, 2006 Report Share Posted September 8, 2006 hii want to get my white industries front freewheel of of my cranks but i cant seem to get it off, my dad cant even get it off, is there a special way of getting it ofany suggestions? the best way i find is to hit your head against it... if that dont work try taking it to your local bike shop!!ben Quote Link to comment Share on other sites More sharing options...
Fvil Posted September 8, 2006 Report Share Posted September 8, 2006 (edited) clamp your crank in a viceso you hav the crank up and the freewheek not facein your body then get the freewheel remover and spanner (attach a long pipe to it so you get MORE leverage) then you should be doneplus HERE if you need help with maintenancein it (cant spell)EDIT:maintenance Edited September 8, 2006 by ffdevil Quote Link to comment Share on other sites More sharing options...
aaron new zealand Posted September 9, 2006 Report Share Posted September 9, 2006 Use a threaded axle and bolt the freewheel remover to the crank with a nut either side. This locks the tool to the freewheel so no risk of rounding the edges. Then clamp the remover tool in the vice. Then get a pipe, cover the crank in a rag and slot the pipe over the crank and wrench it loose. When loosened remove axle as will stop it undoing. Is what we use in our shop. Works perfect every time with no damage to parts. Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 9, 2006 Report Share Posted September 9, 2006 Just make sure you're turning it the right way (i.e. turning it in the same direction you spin the driveshell to make it click)... Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted September 9, 2006 Report Share Posted September 9, 2006 You need about 6 miles of leverage so...What we did was put the crank in a vice and used a metre and a half metal trampoline pole and forced the b*****d off.We've done it with a couple of BB's as well.Leverage is the key Quote Link to comment Share on other sites More sharing options...
