Help!
oddies
hello
im completly new to trials riding but i would very much like to learn.
i have no idea of what bike to get or what type so i wondered if you guys could help me out a bit :$ .
im only 15 and quite short on money, so im not up for buying something thats gonna set back £1000!!!
(PS. if anyone lives in or around brighton in the UK, please tell it would be nice to meet another enthusiast :D .)
Edited by oddies
Hello welcome to Trials , and the forum.
The first thing you need to decide is wether you want to ride mod or stock? (mod 20 inch wheels, stock 26 inch wheels).
If you want a mod then I would recomend an Onza t-pro
But if you want a stock I would recomend an Onza t-rex
Both are good starter bikes in each size.
tom (Y)
Modified (20" wheels)
Pros:
Superb standover clearance
Easily manueverable in most every circumstance, especially anything rear wheel
Less expensive
Less parts to break
Nearly impossible to bend the rim of a well-built 19" rear mod wheel running enough tire pressure
Learn to sidehop up to both sides without worrying about a rear derailleur
Cons:
Some people may think it's a BMX bike
A pain to ride more than a mile or two on
May be harder to find parts for it
Harder to roll down things
Easier to go over the handlebars (but less scary when you do)
Doing wedge or wheelbase moves is less comfortable
Stock (26" wheels)
Pros:
More stable
Bigger wheels = roll everything easier
Easier to do wedge or wheelbase moves
Easier to pedal-kick on odd surfaces because of the larger diameter wheel
You can ride to your riding spot easily (if you have a seat and working gears)
Looks more like a mountain bike
People won't ask you to "grind" stuff or think you do BMX vert or street
Cons:
Bigger bike = less standover clearance = pain if you fall on the bike
Easy to hit knees on top-tube of most bikes
Less room to work with for bending down before sidehopping, bunnyhopping, etc. or when absorbing landings
More expensive because of greater frequency of breakage and more parts to break
Rear derailleurs - easy to smash into things (though most bikes have replaceable derailleur hangers that will bend before the derailleur is broken)
Wheels - 26" size = easier to get out of true or taco (20" wheels are extremely hard to ruin when built and used properly)
Chain can slip down or up a gear while you ride if your chain is too loose, or you smack your derailleur in section and break it
Heavier
For someone who is just starting out, mod will be much easier to learn the basics on.
Stock is more challenging with the same moves as on mod, so if you like a challenge then get a stock(my preference).
Mod is usually more affordable in the begining, seeing as you are on somewhat of a budget I would say go with a mod.
Matt.
