20in Bikes With 19in Rear Wheels
ruckus_street
yea so, i have an onza tvee (20inch rear wheel) and im aware that most mod bikes have 19inch rear wheels. therefore do i have any tyre or wheel upgrade options?
maxxis creepy crawlers have a 19inch rear as do most other tyres i can find, so wouldnt fit my rear wheel. what trials tyres do have a 20in rear that i could fit?
help would be much appreciated
Edited by ruckus_street
i take it your a beginner, so if i was you i would just but up with your set up you have got now and when you are at a better standard and have the money upgrade the frame ect n then you can run a 19' wheel or you could just buy a t-pro. if you are a biginner grip ect doesn't really matter to much becuase you are learning the basics and wont be doing anything big, so it would be bit of a waste of money really as it wont help you improve. hope ive helped mate
Hello i had a onza t-vee to start with to and i got an old t-mag wheel on the rear but i had to get a hs33 because the v-brake would not work because of how small the wheel is but when i did it was a good bike to ride as it is a better wheel then the one that come on the t-vee when you get it i got may one from trials shop,link try it.
