Gear Ratios....some Mathematics
XPbIM3
just cant choose what gear ratio to go on
now iam using 21/18(=1.16666) on 170mm
but may switch to 22/18(=1.22222) or maybe buy some 175mm cranks and go 22/18(it will be like a 1.1873 gear on 170mm cranks)
So the questons are:
Does anybody uses a 22/18 gear ratio with 170mm cranks? & how high/long is your pedal kick?
What is yours recomendations to me? what gear to use?
I run 22:18.
However, I've not been biking all that long - about 4 weeks in total (2 weeks before, and 2 weeks after I'd broken my ankle)
At the minute - I'm getting about 22" high as my sidehop limit (vertical)
About 2.5-3' (feet) across pedal kick (I call them lurches?),
And pedal hoping (to me - lurch again :P ) up is about 12"
I'm on a T-Pro incase you wanted to know ^_^
I couldn't tell you what length my cranks are, I just bought them :P
Can you say if these heights are about normal for my time? Bearing in mind I broke my right ankle and I'm right foot forward so I'm a bit weaker (still re-strengthening)...
I'm a bit worried I'm falling behind , as I have no-one to bike with in my area, I can't compare. (Anyone around the Loughborough area, give me a shout on msn: flipp1@hotmail.co.uk)
I'd say the ratio is very nice to ride, I love it...
Go for it ^_^
Any help?
Flipp
EDIT: 22t sproket is on cranks, 18t is rear freewheel.
Edited by Flipp
i'd go with t-comp-mike guy. go for around the 1.5 ratio mark although thats not a ratio it's self but the sum of. i ride thats and it's the nicest i think.
is a gear ratio calculator thingy not just a normal calculator, or am i being naive. never seen or heard of one, sorry
Edited by weewillywinky
i run 18 16 on 165mm and to be honest since i got my pro 2 i find it harder to gap so im actually thinkin of changing my ratio but dont know what to have i wanna keep the 18 on the front, but i dont want a to easy gear as my bike is the only transportation i really have
use a 18 tooth freewheel and a 12 tooth screw on sprocket thats the most common one and the one im using
you are talking about mod, arent you?
in that case you results arnt bad, keep training
i wish you will recover you ankle completly
freewheel on hub - same config as i have =)
thanx everyone
it seems i have to try 22-18 and maybe get used to it to say exactly will my gap increese or decreese...
