lawrence osborn Posted September 6, 2006 Report Share Posted September 6, 2006 Hey guys, I would like to know how you remove a rear freewheel because when riding the other night my mates freewheel locked and he asked me if i could do anythink about it, so do you need any special tools and the wheel is off an onza t-vee if that helps?Cheers Lawrence Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted September 6, 2006 Report Share Posted September 6, 2006 Right. You need a freewheel tool. It is a four pronged tool with a hex on the end to get a spanner/vive on. Put it into the slots on the freewheel and use your wheelnut to nip it on, mind only nip it, or else the freewheel wont be able to thread off. Nezt jam the tool in the vice HARD. Then turn the wheel anticlockwise and the freewheel should come loose (it will be very tight). then take your wheelnut off and screw the freewheel the rest of the way off with the tool by hand. Then buy a acs Welded freewheel if your on a budget, (a tensile or tryall if your not) and screw it on clockwise by hand making sure that its straight. if it goes tight, take it back off and start again. when it nips on the end of the thread put your bike back together and pedal slowly and it will fully tighten the freewheel(Y)Hope this is a help John. Quote Link to comment Share on other sites More sharing options...
The Duck Posted September 6, 2006 Report Share Posted September 6, 2006 Right. You need a freewheel tool. It is a four pronged tool with a hex on the end to get a spanner/vive on. Put it into the slots on the freewheel and use your wheelnut to nip it on, mind only nip it, or else the freewheel wont be able to thread off. Nezt jam the tool in the vice HARD. Then turn the wheel anticlockwise and the freewheel should come loose (it will be very tight). then take your wheelnut off and screw the freewheel the rest of the way off with the tool by hand. Then buy a acs Welded freewheel if your on a budget, (a tensile or tryall if your not) and screw it on clockwise by hand making sure that its straight. if it goes tight, take it back off and start again. when it nips on the end of the thread put your bike back together and pedal slowly and it will fully tighten the freewheel(Y)Hope this is a help John.I couldn't have said it better myself . I've got a brand new freewheel tool that I can send you for the price of postage. I don't need it. Let me know if you want it matey Quote Link to comment Share on other sites More sharing options...
ogre Posted September 6, 2006 Report Share Posted September 6, 2006 remember to grease the threads now... makes it a bit less of a b*****d to get off next time it goes boom Quote Link to comment Share on other sites More sharing options...
