Fvil Posted September 3, 2006 Report Share Posted September 3, 2006 ok i was wonderin if anyone has hav this problem beforethe orginal Magura bolts are shortwhich has coursed the theads on my frame to strip *it only goes in about 3-4 theads*so its very short so wt i hav done now is got longer boltswhich are doin to job but i m afriad that the next time i hav to adjust the brakesits ll strip the rest of the theadsso i was wonderin if any had done this beforeandif theres a soloution to it part from buyin a new frame or changin to rear disk thanks Quote Link to comment Share on other sites More sharing options...
26inch Posted September 3, 2006 Report Share Posted September 3, 2006 You could drill out the holes slightly larger then tap a larger thread in, then you would be running larger, stronger bolts, you would also have to drill out the magura clamps too Quote Link to comment Share on other sites More sharing options...
Fvil Posted September 3, 2006 Author Report Share Posted September 3, 2006 You could drill out the holes slightly larger then tap a larger thread in, then you would be running larger, stronger bolts, you would also have to drill out the magura clamps tooyer i thought of that as well Quote Link to comment Share on other sites More sharing options...
leemekeetja Posted September 3, 2006 Report Share Posted September 3, 2006 I have the same problem...One of them thread is completely gone So i run v-brakes with adapters...I put some superglue around a magura bolt and just shoved it in And wow, it holds pretty nice actually.But i soon gonna upgrade to maguras, i dont know what happends then.I think i drill the tread off totally and tap new and bigger thread in it.Magura adapters need then drilling too but thats okay with me . Quote Link to comment Share on other sites More sharing options...
court Posted September 3, 2006 Report Share Posted September 3, 2006 hiThere is no point in tapping it as it will be just as strong as it was before .Go to a local engineer and see if they can helicoil it its the strongest way of doing it.It should only cost about 10-15pounds.hope this helpscourt Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 my m8 had this problem and we stripped an old skateboard he had and the bolt was the same thread but longer and this has been working fine since Quote Link to comment Share on other sites More sharing options...
bhups Posted September 3, 2006 Report Share Posted September 3, 2006 (edited) get them helicolied, your local garage you should be able to do it for you. Edited September 3, 2006 by bhups Quote Link to comment Share on other sites More sharing options...
Fvil Posted September 3, 2006 Author Report Share Posted September 3, 2006 my m8 had this problem and we stripped an old skateboard he had and the bolt was the same thread but longer and this has been working fine sincei use to be a skater boi and still hav skate stuffi shall go searchinget them helicolied, your local garage you should be able to do it for you.cant some one tell me what helicolied means? Quote Link to comment Share on other sites More sharing options...
The Duck Posted September 3, 2006 Report Share Posted September 3, 2006 get them helicolied, your local garage you should be able to do it for you.Damn right! Helicoiling is basically where you stick this thing that looks a bit like a screwdriver into the threaded object. Its like a sharp bolt sort of thing (having a bit of trouble explaining ). It just re-threads things. If you still dont have a clue what i'm on about, use the search!! Quote Link to comment Share on other sites More sharing options...
Fvil Posted September 3, 2006 Author Report Share Posted September 3, 2006 i know wt that is...you can make the screw but justin a Dyebut i dont know what the other thing is calledwhich makes the theads in the holesi m sure its somthin like heilcoil Quote Link to comment Share on other sites More sharing options...
