leemekeetja Posted September 3, 2006 Report Share Posted September 3, 2006 (edited) I wonder how much this bike weights.http://www.monty.es/bikes/2006/pdf/230d.jpgMy friend bought one and it seems quite heavy.I wonder why Thanks. Edited September 3, 2006 by leemekeetja Quote Link to comment Share on other sites More sharing options...
Greetings Posted September 3, 2006 Report Share Posted September 3, 2006 It's heavy because of the shocker (at least 1.3kg over traditional rigid forks), seat and seat post (my guess is 0.8kg) and the disc setup (an extra 0.5kg over maguras). In total that gives you over 2.5kgs of extra weight. Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 (edited) It's heavy because of the shocker (at least 1.3kg over traditional rigid forks), seat and seat post (my guess is 0.8kg) and the disc setup (an extra 0.5kg over maguras). In total that gives you over 2.5kgs of extra weight.i think maguras weigh more than discs do, but that all depends on the discs anyways it will weigh more mainly because of the forks suspension forks also mean less control i dont know why monty have done this but i would get new forks Edited September 3, 2006 by I-LUV-TRIALS Quote Link to comment Share on other sites More sharing options...
adamtrials Posted September 3, 2006 Report Share Posted September 3, 2006 i think maguras weigh more than discs doThey dont.The sus is because it's a "street" bike. Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 They dont.The sus is because it's a "street" bike.i ride street and dont need sus its pointless really unless your crap and keep landing on your front wheel Quote Link to comment Share on other sites More sharing options...
Walleee Posted September 3, 2006 Report Share Posted September 3, 2006 i ride street and dont need sus its pointless really unless your crap and keep landing on your front wheel Well you know, I ride downhill's and I don't need a downhill bike, yet some people do. Nothing is pointless, the point is to absorb the shock which would otherwise go straight to the rider.and finally, Adam is right, Disc's generally weigh more than magura's when you take into consideration the extra tabs on the hub, the disc itself, the calipers and the lever, where magura's are just 2 calipers and a lever. Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 Well you know, I ride downhill's and I don't need a downhill bike, yet some people do. Nothing is pointless, the point is to absorb the shock which would otherwise go straight to the rider.and finally, Adam is right, Disc's generally weigh more than magura's when you take into consideration the extra tabs on the hub, the disc itself, the calipers and the lever, where magura's are just 2 calipers and a lever.thats confusing as i am called adam lol, but with maggies you have the to calipers, mounts, lever, hose and a big sidewall whereas on a disc only rim you dont need huge sidewalls therefore the rim can be lighter.and a disc only has 1 caliper but 1,2,4 or 6 pots (pistons) so.... Quote Link to comment Share on other sites More sharing options...
Walleee Posted September 3, 2006 Report Share Posted September 3, 2006 look, Ill start being pedantic about this if you want, or you can take my word for it that generally maggies are the lighter option. a big sidewall? dead on.You have hose with disk's too The rim could be lighter using carbon fibre, but like I said generally, maggies are the lighter option.Magura's - Weight: 315g per brake, including 4 bolt mounts. Discs - Formula Weight: 388g (including all bolts, rotor, and full length hose) Hope Weight 408g including full length hose and, all mounting hardware. ok? Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 You have hose with disk's too i never said you didn't have a hose on a disc but i also didn't mention that the pads on a maggie are heavy and wont be included in the overall weight. Quote Link to comment Share on other sites More sharing options...
King C Posted September 3, 2006 Report Share Posted September 3, 2006 (edited) but i also didn't mention that the pads on a maggie are heavy and wont be included in the overall weight. what pads are you running?Just face it discs are heavier especially if you have a large rotor ie 203mm. Edited September 3, 2006 by kcchan Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 what pads are you running?Just face it discs are heavier especially if you have a large rotor ie 203mm.any ways i dnt care they work better lol Quote Link to comment Share on other sites More sharing options...
Walleee Posted September 3, 2006 Report Share Posted September 3, 2006 It's a matter of opinion as to which is better, I seriously doubt a Downhiller would say maggies are better than discs.I can assure you, pads weigh about 25 grams each or something silly like that, still making maggies lighter than discs. Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 (edited) It's a matter of opinion as to which is better, I seriously doubt a Downhiller would say maggies are better than discs.I can assure you, pads weigh about 25 grams each or something silly like that, still making maggies lighter than discs.lol what ever but discs are good all round ive done downhill dirt jump and trials and i would recomend them for anyone who wants seriouse braking that works in any weather Edited September 3, 2006 by I-LUV-TRIALS Quote Link to comment Share on other sites More sharing options...
adamtrials Posted September 3, 2006 Report Share Posted September 3, 2006 lol what ever but discs are good all round ive done downhill dirt jump and trials and i would recomend them for anyone who wants seriouse braking that works in any weather Sounds like something you'd read in a Raliegh catalogue... Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 Sounds like something you'd read in a Raliegh catalogue...does that mean you read raliegh catalogues? lol Quote Link to comment Share on other sites More sharing options...
Greetings Posted September 3, 2006 Report Share Posted September 3, 2006 i think maguras weigh more than discs do, These are the figures (weighed by me):Rear 05 Maggie with mounts - 242gHope Trials with 180mm disc - 420g (or something similar). Note that this brake has an extremely lightweight rotor making it very light comparing to other brakes with similar power. Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 (edited) These are the figures (weighed by me):Rear 05 Maggie with mounts - 242gHope Trials with 180mm disc - 420g (or something similar). Note that this brake has an extremely lightweight rotor making it very light comparing to other brakes with similar power.i'm curious as to weather you had a lever attached to that maggie if you did check your scales!!!!!!!!!!!!!!!! Edited September 3, 2006 by I-LUV-TRIALS Quote Link to comment Share on other sites More sharing options...
Joe_Elding Posted September 3, 2006 Report Share Posted September 3, 2006 i'm curious as to weather you had a lever attached to that maggie if you did check your scales!!!!!!!!!!!!!!!!i'm curious as to how one person can be so f**king stupid. Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 i'm curious as to how one person can be so f**king stupid.woooo calm down, pmt lol its a bit obvious that a maggie and mounts weigh more than 242g Quote Link to comment Share on other sites More sharing options...
Up'n'away Posted September 3, 2006 Report Share Posted September 3, 2006 (edited) Dude... You're a Class A Twat!'Scuse my french or w.e but f**king Hell Man!EDIT: oh my god!!?!! HE SAID HIMSELF THAT HE WEIGHED THEM!! Edited September 3, 2006 by Up'n'away Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 3, 2006 Report Share Posted September 3, 2006 Dude... You're a Class A Twat!'Scuse my french or w.e but f**king Hell Man!EDIT: oh my god!!?!! HE SAID HIMSELF THAT HE WEIGHED THEM!!i dunno y your sayin tht u dnt even no me!!!!and y may i ask do u think this Quote Link to comment Share on other sites More sharing options...
Greetings Posted September 3, 2006 Report Share Posted September 3, 2006 woooo calm down, pmt lol its a bit obvious that a maggie and mounts weigh more than 242g I'm SO sorry, I forgot to weigh the screws, so here's your 266g as opposed to 242. Why does one have to prove everything one says? The brake isn't resting on anything so don't you jump to conclusions. Quote Link to comment Share on other sites More sharing options...
Si-man Posted September 3, 2006 Report Share Posted September 3, 2006 LMFAO!!Silly NM's haha! Quote Link to comment Share on other sites More sharing options...
bhups Posted September 3, 2006 Report Share Posted September 3, 2006 (edited) LMFAO!!Silly NM's haha!Will they ever learn lol basically, maggie is lighter end of! Edited September 3, 2006 by bhups Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted September 4, 2006 Report Share Posted September 4, 2006 dont tell me you took your maggie off just to weigh it lol but al im sayin is someone on here before you said they wiegh more??? Quote Link to comment Share on other sites More sharing options...
