Bmx Help
watto
Right i have just bought a 14t acs to get my gear ratio slightly better, but due to me running a 'fat' motorbike style chain and the acs having a raised part on the freewheel the chain isnt sitting properly when pedalling and generally feel shyte, good i machine donw that part of the freewheel or is it a better idea getting a cassette hub as my ratio at the moment is 32t>14t.
32t-14t you should be runing a 38t with a 14 but you could get an odessey freewheel which is a 13 but the gearing will still be out -
heres the gearing ratios
44 - 16
38 - 14
36 - 13
33 - 12
30 - 11
28 - 10
25 - 9
hope this helps
I do know what the supposed gear ratios are for bmx ive bin riding on and off for 3 years, i don't like those ratios, i like mine a bit more spinny to be honest, i am no thinking due to it being my bithday soon get the same wheel but with a eastern cassette hub and sell this one, and have a look into chains.
the hub i had on my bmx was an odyssey hazard, its really good but expensive sounds nice aswell a loud sharp click B)(Y)
I don't trust kool chains or any of that shite if im going to be grinding on them so i know where you're coming from with the chunky chains.
the big fat gusset chain that isn't motorbike thickness (ie. not the bog chain, the other one) will be plenty strong enough. They're only a tenner so that'd be the first thing i tried
my advise to you would be to get a 12t cassete hub as they are much better than using a standard freewheel. Hope that helps
and where chains are concerned you should get a shadow conspiricy chain, they are the best chain i have ever had and are practically unspapable. (Y)
