kyle-livesey Posted August 28, 2006 Report Share Posted August 28, 2006 hi i can tap about 45 but i carn't seem to get to back any advise Quote Link to comment Share on other sites More sharing options...
max-t Posted August 28, 2006 Report Share Posted August 28, 2006 hi there. are you going at it fast?and where are you hitting the wall? a vid would be helpful to both me and you if thats possible?max... Quote Link to comment Share on other sites More sharing options...
kyle-livesey Posted August 28, 2006 Author Report Share Posted August 28, 2006 hi im hitting it as fast as possible and hitting it at about 1half brick from top as for a vid ant got on but i am making it Quote Link to comment Share on other sites More sharing options...
max-t Posted August 28, 2006 Report Share Posted August 28, 2006 yer sounds like you are hitting it in the right place...whats the problem then? is your momentum stopping when you hit the wall or are you having trouble converting the bounce off the tap into height. Quote Link to comment Share on other sites More sharing options...
Jay@BBT Posted August 28, 2006 Report Share Posted August 28, 2006 What i found helped was hitting the wall slightly lower down..? Gives more of a bounce up.Jay Quote Link to comment Share on other sites More sharing options...
lawrence osborn Posted August 28, 2006 Report Share Posted August 28, 2006 I found that if you hit the wall around the same place and really give it beans and also when you hit the wall hit it with the bike more vertical and for some reason that works! Heres a drawing sort of explaining it (sorry about the great drawing) Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted August 28, 2006 Report Share Posted August 28, 2006 I find tapping odd. I tryed so hard to keep the front wheel high.But I made a vid that is slowed down. Its not the best tap ever, cause its by me. But maybe people can give me tips too.[attachmentid=6676]Do I tap too far up the wall? I do carry a bit of speed into it though. I'll just practise though, when I can walk!http://tv.isg.si/site/filebrowser/MattGibsonThe video is on there, its called Tapping Quote Link to comment Share on other sites More sharing options...
Guest Posted August 28, 2006 Report Share Posted August 28, 2006 Id imagine you can do that straight to back wheel without tapping??I would have thought you'd need a taller wall to tap properly. Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted August 28, 2006 Report Share Posted August 28, 2006 (edited) Id imagine you can do that straight to back wheel without tapping??I would have thought you'd need a taller wall to tap properly.Yeah I can, i was seeing if I could tap, turns out I can. Not that good.EDIT: The wall looks pretty small on there, Its just above bar level. Edited August 28, 2006 by Matt Gibson Quote Link to comment Share on other sites More sharing options...
Guest Posted August 28, 2006 Report Share Posted August 28, 2006 Yeah I can, i was seeing if I could tap, turns out I can. Not that good.EDIT: The wall looks pretty small on there, Its just above bar level.I'd probobly be trying it on something a bit bigger if you can, something which you can nearly backwheel would be good as you'll know you've got the tapping technique right when you make it.... Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted August 28, 2006 Report Share Posted August 28, 2006 I can do it both. Next I'll make a "hall" out of pallets about 6inch bigger than that and tap that, make it bigger by another 6tap that and so on. Just keep practising, all I need to do. Quote Link to comment Share on other sites More sharing options...
kyle-livesey Posted August 29, 2006 Author Report Share Posted August 29, 2006 thanks for the tips any more Quote Link to comment Share on other sites More sharing options...
Saracen Kid Posted August 29, 2006 Report Share Posted August 29, 2006 I found that if you hit the wall around the same place and really give it beans and also when you hit the wall hit it with the bike more vertical and for some reason that works! Heres a drawing sort of explaining it (sorry about the great drawing)love your artistic skill Quote Link to comment Share on other sites More sharing options...
