Ben Beckett Posted August 27, 2006 Report Share Posted August 27, 2006 i need help with this trick, i can get the front wheel on the top n the back wheel on the side but then i fall off backwards, i cant seem 2 get the bike up! please helpmuch appretiatedben Quote Link to comment Share on other sites More sharing options...
JonCongreve Posted August 27, 2006 Report Share Posted August 27, 2006 The basic advice i've heard people say....is to carry momentum from going into the pallet, to helping lift the bike up in the hook.As soon as you hit the pallet/wall carry the momentum over the bars while bringing the rest of the bike up I'm not very good at them at all, but i hope this has helped Quote Link to comment Share on other sites More sharing options...
python_man Posted August 27, 2006 Report Share Posted August 27, 2006 the way i do it is pedal like a nutter just lift the front end and land your front wheel on the wall and smack your rear wheel into the wall. as soon as you've done this lift forward and get your weight over your bars and you should be up the obstical keep doing this until you get the whole move as smooth as a babys bum and your sorted.remember loads and loads of speed more speed easier the hook will be Quote Link to comment Share on other sites More sharing options...
Greetings Posted August 27, 2006 Report Share Posted August 27, 2006 ^^^ true. And theres also two other things: -If you're doing a pedal up, pedal from the moment you start moving to the very end of the pedal up. In other words, keep pedaling. This is quite tricky but it does help once you get the hang of it. -Get the whole body weight onto the front wheel and fork. The rear wheel has to remain weightless.Good luck with them. Quote Link to comment Share on other sites More sharing options...
max-t Posted August 27, 2006 Report Share Posted August 27, 2006 (edited) basically what they said mate^^^^^but when you hit it throw all of your body forward and use your front brake to help you up..dont lean forward too soon though because you will stop dead..when you go up it push the bars away from you and unweight your feet from the pedals...the back wheel should follow ..keep practicing and hit it hard !max and you have posted a few topics already..nice one! Edited August 27, 2006 by max-t Quote Link to comment Share on other sites More sharing options...
Luke Drewery Posted August 28, 2006 Report Share Posted August 28, 2006 I have recently just learnt hooks and there is a nack to it that involves landing on the wall both wheels at the same time and with your weight forward, this way when you hit the wall the momentum does most of thw work for you, you just lift the bike and lean forward and you should make it up safely. The problem I had was that I didnt have enough speed and I kept my weight too far back so when I landed I did what you do at the minute and fall back. So basically hit the wall hard, fast and with your weight forward and you should get up! Quote Link to comment Share on other sites More sharing options...
Ben Beckett Posted August 28, 2006 Author Report Share Posted August 28, 2006 thanks alot you kind kind people, , i will try it today! cheets ben Quote Link to comment Share on other sites More sharing options...
Ben Beckett Posted September 2, 2006 Author Report Share Posted September 2, 2006 yeah um right, i tried it and couldnt do it. ill try it again but video it so you can see if its goin right or not. any more advice/tips are much appretiated.thanks ben beckett Quote Link to comment Share on other sites More sharing options...
Ali C Posted September 3, 2006 Report Share Posted September 3, 2006 two main things..............SPEED and WEIGHT FORWARDS, get those two right and you'll probably get up Quote Link to comment Share on other sites More sharing options...
Connor Posted September 3, 2006 Report Share Posted September 3, 2006 (edited) Once you've got the hang of them they feel mint! you just fly to back wheel, basically a hook is all about speed and getting used to smacking your bike in a wall at a vertical angle, feels weird because how often are you ever vertical on a bike, just takes time to get used to it, shift your weight as hard as you can to the front wheel and your back should just come straight up but if your trying for a hook to back as your rear wheel comes up stick your arse and weight to back and the same will happen to the front .I also reccomend that you start on a slant but get to a vertical wall soon after just keep trying over and over, you will get it good luck mate. Edited September 3, 2006 by Snowy Quote Link to comment Share on other sites More sharing options...
t33zr Posted September 20, 2006 Report Share Posted September 20, 2006 yeah, i know this is a old thread.. I have a little question...How do you guys use the brakes when you hook?I can do hooks but i dont go straight to back... so i was thinking that maybe i use wrong method with the brakes... Quote Link to comment Share on other sites More sharing options...
