My Wheel Wont Fit The T-pro Frame
$IL3NT.
don't do this as one day your da bomb wheel will just collapse and die 'n' stuff so then you'll be wanting a new wheel and chances are you'll be wanting a 'proper' wheel, I can see it sliding about in your droupouts myself. Something will go wrong anyway.
I'm sure someone can elucidate.
NOOOOOOOO lol.
The wheel is probs 20" and has different spacing or something, you will need a new hub/wheel.
Or wait for someone else to reply, 'cause I don't know much about Da Bombs.
Mat
yea da bomb wheels are 20" mate.
Your going to be getting a new mod wheel sooner or later anyway. Whats wrong with sooner? ;)
You're trying to put 10lbs of shit into a 5lb bag, or in this case trying to fit a 14mm axle into a 10mm frame. Don't ruin the frame for the sake of the wheel - you could either get a new hub or just slot the axle, meaning you slice off the top and bottom part of the axle (so measure down 2mm down from the top then 2mm down from the bottom, then cut across) so it'll slide into the dropout. They do that with some BMXs so it does work, but really, just try and get a new hub. They aren't super expensive or anything, so just try that first (Y)
Hi,
well i think silent should drill his rim dropouts out to fit a 14mm axcle, my friend tom who bought a koxx djinn frame realized that his axcles were too big for the dropouts so he just drilled them to fit, hes now had the frame about 2 months and hes quite a harsh rider... and its all fine.
Then you wouldn't have to pay to get a new hub and spokes.
And any you can buy mission 14mm axcle hubs, i don't think there too bad, any who cares about a decent hub..well i don't!
Tim. (Y)
yes good memory i did have a shogun lol i dont think my rear wheel is 20" i think its 19" but i think i will just need a new hub i suppose
heres a pic of my rear wheel .....
IPB Image
CLICK THE PIC TO ENLARGE
Edited by $IL3NT.
If you dont wanna buy a new axle, read on. Take the axle out. Lathe of the axle to the size of you mounts and then re-tap the axle. Otherwise you can just by new hub and stuff if you dont have access to the equipent (Y)
Mat
If you measure across the rim to measure the diameter of the wheel which you are wanting to use then you will be able to determine for definite whether or not it is the right sized wheel. If it is then you can simply cut all of the spokes off and put it in the post to tarty bikes where a cheap T-Pro standard hub is 15 quid, a wheel build is 10 quid plus 2 quid for a final true and spokes are about a tenner. So you could have a decent wheel for forty quid.
Remember that the strength of a wheel is in its spokes not the rim, so i'd have thought that the rim would be fine.
Alternatively you could buy an onza wheel for around sixty quid.
I hope I understood your problem properly, I wasn't too sure somehow.
Bob
ok is there any cheap alternatives just for now because i want to ride as soon as i can
for instance buying a BMX hub or rim :ermm:
because my local bike shops dont stock trials gear and they try ripping you off
but they dont fool me :P
any alternatives ?
Posting a rim to a specialist bike shop will not take long.
You will be able to find the cheapest one for wheel builds and spares.
You will be able to read reviews on here to see which bike shops are reliable, in my experience, if they don't have a good selection of spares, then they have poor mechanics aswell and will take ages to build up a wheel and may not do a very good job.
Just my thoughts, i can understand you'r problem though.
Bob
Just for the record....GET A NEW REAR WHEEL!!! i used to own a da bomb...going from 10mm to 14mm is fine because you get adaptors.....But you can't get adaptors to make things smaller....don't drill your frame 'n' that !
zoo baby!
  • 1 year later...
