Front And Rear Iso Disc Mounts
manuel
but what about the 4mm spacing difference - does that come out in the wash due to disc position on the hub ?
so if i wanted to use a rear caliper on the front id need a 20mm smaller one and then a different disc ?
Edited by manuel
The only difference between the front and rear ISO disc mounts is the 20mm spacing, so if you had a rear caliper designed to fit a 160mm rotor, and you put it on the front, it would fit fine, but it would need a 180mm rotor. that's all, and it obviously works the other way round. IE 180mm front = 160mm rear.
Yep (Y)
To use a rear caliper on the front, you'd need a 20mm larger rotor. For example, if the brake was a 160mm on the rear, then you'd need a 180mm rotor to run that same caliper up front.
Ads
