Barbra Posted August 22, 2006 Report Share Posted August 22, 2006 Well after i bent my old rotor, ive been riding my bike for a while, but i left the brake on the bike (even though i had no rotor) and a few times i pressed it accidently. Now ive got a new rotor, hopo mono trial 160mm it rubs against the pads. Ive looked down at the pads and one side sticks further in than the other, and won't push back into place where it should be, to give the disc enough clearance not to rub. Would bleeding the disc sort this problem? Quote Link to comment Share on other sites More sharing options...
JonCongreve Posted August 22, 2006 Report Share Posted August 22, 2006 I'm sure someone can give a better explanation but....as it is an open system (i think) when you push the lever when there is no rotor in beteween the pistons, the pads will move out and stay there.All you need to do is take the rotor out, and use a small scredriver the seperate the pads/pistons apart, so they are back to normal.It's best to take your pads out, so when seperating the pads, you don't damage them Hope i've helped Quote Link to comment Share on other sites More sharing options...
Barbra Posted August 22, 2006 Author Report Share Posted August 22, 2006 oh yea, i get you mate, i'll give that a go when i get my freewheel off. Which is the biggest pain in the arse ever. Halfrauds couldn't even do that with the actual tool Quote Link to comment Share on other sites More sharing options...
ben Posted August 22, 2006 Report Share Posted August 22, 2006 if you have done a sketchy bleed like me where you basicaly fill the resivoir up then open it as you cant push the pistons back as the systems full if that makes sence to you. it might also just be a spacering problem 9i take it you have a shim set) or maby the forks need faceing hope do it kit but i think there quite expensive so id get a bike shop to do it we have one at our halfords hope that was some help.ben Quote Link to comment Share on other sites More sharing options...
Synergy Posted August 22, 2006 Report Share Posted August 22, 2006 if its one side thats rubbing why dnt you get a washer on the disc mounts on the forks to push the side over a bit more so the disc is a more central area inbetween the pads? Quote Link to comment Share on other sites More sharing options...
Barbra Posted August 22, 2006 Author Report Share Posted August 22, 2006 if its one side thats rubbing why dnt you get a washer on the disc mounts on the forks to push the side over a bit more so the disc is a more central area inbetween the pads?Ahhhh, nice idea sir Quote Link to comment Share on other sites More sharing options...
26inch Posted August 22, 2006 Report Share Posted August 22, 2006 you should just be able to push the pistons back, use a tire lever or something Quote Link to comment Share on other sites More sharing options...
Barbra Posted August 22, 2006 Author Report Share Posted August 22, 2006 its all sorted nowThanks all. Quote Link to comment Share on other sites More sharing options...
Si-man Posted August 22, 2006 Report Share Posted August 22, 2006 Spacing shims and fork facing are your friends. Quote Link to comment Share on other sites More sharing options...
