Oddball Posted August 20, 2006 Report Share Posted August 20, 2006 Evening all, I did my first wheel build today, took about 2 hours but its all good! I then put on my hope mini rotor (203mm) and then tried slotting it into the pads and ive found the rotor is to big...or the calliper is to close so my question's are, What is the biggest rotor I can have? Or can I keep this rotor but get an adaptor to take the calliper away from the original mounting points?Also, whilst I’m here, I need some new pads but don’t know what to get or what shape and stuff, as ive looked about on eBay but there’s quite a few types.Thanks guys!Anf.P.s ive got a number 6 hope mini calliper...don’t know if this information helps but saves you asking for it Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 20, 2006 Report Share Posted August 20, 2006 P.s ive got a number 6 hope mini calliper...don’t know if this information helps but saves you asking for it Are you sure its a number 6? I believe they only made the DH4 and Enduro 4 in number 6... You might have a 5? Or 3?CheersAdam Quote Link to comment Share on other sites More sharing options...
Oddball Posted August 20, 2006 Author Report Share Posted August 20, 2006 (edited) Are you sure its a number 6? I believe they only made the DH4 and Enduro 4 in number 6... You might have a 5? Or 3?CheersAdamYep it says 6 on it... here's a pic I just took: [attachmentid=6564] Edited August 20, 2006 by Oddball Quote Link to comment Share on other sites More sharing options...
JT! Posted August 20, 2006 Report Share Posted August 20, 2006 OT, but have you read any of my PMs or emails??? Quote Link to comment Share on other sites More sharing options...
Oddball Posted August 20, 2006 Author Report Share Posted August 20, 2006 OTOT? Quote Link to comment Share on other sites More sharing options...
Caleb Posted August 20, 2006 Report Share Posted August 20, 2006 means off topic Quote Link to comment Share on other sites More sharing options...
Oddball Posted August 20, 2006 Author Report Share Posted August 20, 2006 means off topicAh, ok thanks mate. Is there one for, lets get back on topic? Anf. Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted August 20, 2006 Report Share Posted August 20, 2006 I *think* 6 is for a Boxxer fork, did you buy this brake second hand and this is the first time you have come to fit it yes? in that case You will most likely need a ''normal'' caliper half, 3 is 185 so maybe a 5? Quote Link to comment Share on other sites More sharing options...
Oddball Posted August 21, 2006 Author Report Share Posted August 21, 2006 I *think* 6 is for a Boxxer fork, did you buy this brake second hand and this is the first time you have come to fit it yes? in that case You will most likely need a ''normal'' caliper half, 3 is 185 so maybe a 5?Bugger... yes this is the first time I’ve tried to fit it, is there nothing else I can do? E.g. get a plus 20/40 from tarty bikes, or even get a smaller rotor or something?Thanks, Anf. Quote Link to comment Share on other sites More sharing options...
Danny Posted August 21, 2006 Report Share Posted August 21, 2006 If you get in touch with hope they may be able to make you a rotor to suit. Quote Link to comment Share on other sites More sharing options...
Oddball Posted August 21, 2006 Author Report Share Posted August 21, 2006 Ok cheers, ill just ring them up and ask them about it all.Thanks anyway guys, Anf. Quote Link to comment Share on other sites More sharing options...
