My Tensile
monty boi
You could tighten the lockring by using something small and pointy for example: an old spoke or a small screwdriver and insert into one of the little holes on the freewheel and turn until tight.
If the tensile is faulty then depending where you got it from, you could get a refund as long as it is still under its warrantee.
A little gun shaped peice of metal has just fallen out and i can see all the bearings now?
what should i do? as i say i have only had it on the bike 2 weeks here are some pics
IPB Image
IPB Image the peice of metal that has fallen out :( someone please help.
Adam. (Y)
mate, f**k me that's a pawl.
I'd say send it back for a replacement or whatever, by the sounds of things you wouldn't want to try and replace the bit's yourself and you'd still have the problem of it loosening.....
that totally defeats the purpose of buying one really, kinda like a pimped ACS......
