Onza Limey Bottom Bracket
simple_simon
i've recently bought the new onza limey frame, and cause i'm lazy i had tarty bikes fit the bottom bracket
my problem is the bottom bracket seems well too long and flexes wen i pedal 2 hard i cant put a smaller one on because my cranks would smack into my brake thingys (i don't no the name) but anyway any advice
On new frames, bottom brackets do sometimes come loose though. Just hold the cranks so they're horizontal, grab hold of the ends of your cranks nearest the spindle, and try pushing one side up and one side down. If there's play there, the BB is loose. Either way, longer square taper BBs tend to be flexier than longer ISIS BBs, so maybe attempting to make the switch to ISIS some time soon might help?
