Setting Up A Mech
Fishy
Right, I've decided the Dmr tensioner was shit, and it broke, so I've replaced it with a Shimano Sora mech. It fits fine, but the only problem is it doesn't stay inline with the chainring or rear sprocket. Is there something I can do to make it stay inplace, but keeping the tension?
I do have a kind of idea, but how do I hold the cable through the 'furrel'. The is some wire on already, under a bolt, but it isn't doing anything. Sorry about all these questions, but it's getting right on my boobs.
Well if there's no 'furrel' then you'll have to find a way of holding the cable in place....?I'm not sure how you could do this.Once you have the cable through the 'furrel' part nicely attached, jus adjust the chainline and tighten the bolt up to hold the cable and therefore mech in the correct place :)
right...this is absolute genius...
take out the big spring in the middle of the mech (pliers?), then get a longer bolt to put in the lower limit hole....this pushes against a sticky out bit inside the mech and makes your bike stay in whichever gear you choose- i'll get a pic of mine tomorrow if you like...
for more security, drill out the upper limit hole to at least M5 and put in a longer bolt....with both these bolts, the mech cannot move into any other gear
you can also change gear if you want to....and there's no cable (which, if like me you sidehop to the right, you keep breaking)...
credit to "gears" for this idea...although i've modded it for myself...
adam
adam
Can't believe you still have that mech :lol: , Anyway yeah. Thats the best idea.
The 'ferrul' that you were talking about is a barrel adjuster. Just like on cable brake levers.
Use the end of a brake cable (bit that's usually in the lever) at the top of the barrel adjuster. - Like in the pic a few posts above.
make sure the chain's on.
Pull the cable so it's relativly tight, then do up the bolt.
Now pedal the bike, if it falls towards the dropout, take a look under the mech, and you'll see a plate that the two H/L screws press on. These are caklled the Limit stops.
Whichever screw is touching the plate, loosen it to move the mech away from the dropouts, and vice versa.
Just fiddle around with that untill it stays in place. (Y)
adam
Cheers to me more like it... its my bodge, i did it for him and many other local riders around here. Its by far the best and easiest bodge and if done correctly, will lead to a mech thats adjustable by hand within a matter of seconds.
Edited by Krisboats
