Wright Pads Posted August 16, 2006 Report Share Posted August 16, 2006 Ali i gotta drawing soemthing up asapA4 is what i got but can get A3, how the hell do i do a scale? Like the scale you did on the last drawing you did for me dude! Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted August 16, 2006 Report Share Posted August 16, 2006 He's in singapore, so unless he can get to a pc he probably wont answer you Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted August 16, 2006 Author Report Share Posted August 16, 2006 jammy bugga only if i knew he could of brought back my gfxz insted of me speding £3k on em today..mehAnyway 1115mm wb i need to scale it down to fit on an A4 sheet but maths today is over my head!!! help somone? Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 16, 2006 Report Share Posted August 16, 2006 If you want a quick way to do a scale, I guess you could just take an A4 piece of paper, work out how much border you want it to have, then just divide the wheelbase by that amount (don't forget you won't have room to put the wheels in unless you add on in mm the radius of each wheel to the wheelbase)? So if you wanted to have 10mm of borders, that'd mean 297 - 10 - 10 = 277, so 1115/277 = ~4, so you could go with a 1:4 scale and have it fit on? Meaning you'd have to just divide the "real" measurements by 4 to get the correct size to draw them on paper.Quick way of doing it I guess, even if it may not be "The" way? Quote Link to comment Share on other sites More sharing options...
