Tim-Hill..Yeah Mate Posted August 15, 2006 Report Share Posted August 15, 2006 hello,today my brake was re-bleed and when the brake is pulled both pads come out and stay out, i don't know what the problem is, is it that theres too much fluid in my brakes? i can push them both back in but the don't stay in.Can anyone help?I've used the search and couldn't find the correct answer.Tim. Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 15, 2006 Report Share Posted August 15, 2006 Take the wheel out, take the pads off.Squeeze the lever in.With the lever squeezed in, spray some GT-85 or similar spray lube (not WD-40 though) onto the pistons that are sticking out. Pump the lever in and out, then hold them out again. Wipe down the pistons, then re-lube them. Should solve it. If you wanna go Pro, get someone to hold one of the pistons in so the other fully extends.Also, when you're setting it up, make sure you don't use too much TPA (the dial on the lever blade), 'cos that'll mean they won't react fully. Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted August 15, 2006 Author Report Share Posted August 15, 2006 hi,yeah i have lubed my pistons with soap lol but surly that would work, its thick enough?. but lubing them still didn't help.Tim. Quote Link to comment Share on other sites More sharing options...
Fvil Posted August 15, 2006 Report Share Posted August 15, 2006 Tim Tim Tim loltry movein them closer to the rim might helpoh wait your online Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 15, 2006 Report Share Posted August 15, 2006 Tim H said: hi,yeah i have lubed my pistons with soap lol but surly that would work, its thick enough?. but lubing them still didn't help.Tim. Use a real lube Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted August 15, 2006 Author Report Share Posted August 15, 2006 Hi,I don't have an "real lube".. anyway i've just lubed them as you said but with fairy liquid which is a little slipperyier than soap sooo mite be okay in the morning?it feels like theres too much fluid in there though because it just cant stay in!cheers anyway.Tim. Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 15, 2006 Report Share Posted August 15, 2006 If there was too much fluid, they wouldn't go back in at all. It's a closed system, so all the fluid's in there all of the time, basically. Again, Fairy liquid won't work the same as a PTFE-based lubricant.This is £2.99, with free next day delivery, and you'll be able to use it for all sorts of jobs on your bike, so just invest in some of it and then you'll be able to service all the stuff on your bike properly, which is all good.Like I said though, maybe try winding the TPA out (so the lever flaps around more). Oh, and one last thing - double check the lever blade bolt hasn't tightened itself Quote Link to comment Share on other sites More sharing options...
Fvil Posted August 15, 2006 Report Share Posted August 15, 2006 I notry lubing the piston in the leveras it may be dry and not returing well Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted August 15, 2006 Author Report Share Posted August 15, 2006 Ah that could be it, they haven't been lubed for ages! cheers i'll give it a trythanks Tim. Quote Link to comment Share on other sites More sharing options...
max-t Posted August 16, 2006 Report Share Posted August 16, 2006 it sounds to me that you have bled the brake with the tpa adjusted all the way ...re bleed it with the tpa adjusted off and the pads will return hopefully lolmax.. Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted August 16, 2006 Author Report Share Posted August 16, 2006 (edited) Hi,when the brake was bled the tpa was right out as in not in the lever, is that not what your supposed to do?i've lubed pistons inside my lever and now the pads return but still poke out a bit and now its not too bad i just move the pads a little further away from rim to stop rubbing.thanks guys Tim. Edited August 16, 2006 by Tim H Quote Link to comment Share on other sites More sharing options...
Fvil Posted August 16, 2006 Report Share Posted August 16, 2006 Tim H said: Hi,when the brake was bled the tpa was right out as in not in the lever, is that not what your supposed to do?i've lubed pistons inside my lever and now the pads return but still poke out a bit and now its not too bad i just move the pads a little further away from rim to stop rubbing.thanks guys Tim.dont you mean thank you me ha ha ha ha good advice every one Quote Link to comment Share on other sites More sharing options...
max-t Posted August 16, 2006 Report Share Posted August 16, 2006 Tim H said: Hi,when the brake was bled the tpa was right out as in not in the lever, is that not what your supposed to do?i've lubed pistons inside my lever and now the pads return but still poke out a bit and now its not too bad i just move the pads a little further away from rim to stop rubbing.thanks guys Tim.your supposed to have the tpa the other way.all the way in the lever blade.although i think thats what you mean? oh well seems that you have sorted it now Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 16, 2006 Report Share Posted August 16, 2006 Nah, the TPA needs to be out so you get the full amount of fluid in the system, giving you the most adjustment with the TPA Quote Link to comment Share on other sites More sharing options...
Tim-Hill..Yeah Mate Posted August 16, 2006 Author Report Share Posted August 16, 2006 Hi,brake is all sorted now i had to do around 6 lubes on the left hand side piston before it started loosening up, i used supergrade engine oil lol but it worked pretty well.thanks for all the tips and advice.Tim. Quote Link to comment Share on other sites More sharing options...
