Cassette Won't Budge.
Fishy
Right gutys, I've got my lockring off, but i can't seem to get the cassette off. the last gear fell off after taking the lockring out, but the others are well and truely stuck in...
any ideas on how to get the f**ker out?
Cheers in advance.
Probably dug into the freehub body slightly, I had the same problem last time I pulled my cassette off.
Have you got a chain whip? Best bet is probably to wrap that around the middle of the cassette block and try to loosen it off.
Other than that, not too sure how 2 go about it, bar a big hammer but I wouldnt advise!
M@
Edit: Not quick enough clearly :$
Edited by MadChikken
Simon: Thats whats happened I think, b*****d won't come off. Atleast I get to use my grinder... :)
I don't have a chain whip, but i have a grinder, and a big hammer...
Edited by Joe Rothwell
Hit the rings with a hammer opposite to the direction your hub engages. Instead of using a chainwhip you can get a piece of wood, nail an old chain on and you hav your very own chain whip.. or just jam the wood against the rings your not hitting.
Do you mean like a spacer? If so I used a flat head screwdriver to get under it and prise it off, the further it gets the wider head screwdriver you need to prise it further!
Davey
Edited by Small_Gear_Big_Style
No, a lockring. It's off a different wheel, with a SS kit on it, i need the spacers off it. The wheel i couldn't get the cassette off is the wheel is use at the mo. I'm changing it to SS.
Any ideas on how to get the b*****d off?
Without a chain whip it's tricky because you're unscrewing in the freewheel direction, try using mole grips on the sprocket to hold the freewheel while you give the lockring hell, I assume you got the lockring tool? This isn't advised if you actually want to use the sprocket afterwards by the way, lol!
Davey
Might be a LBS job, only other thing I can think of is try using a length of chain, if you can get a decent grip on it, maybe hold it with a rag or something wedged through the gaps between the links, and use that like a chainwhip, because it's basically the same but without a convenient handle!
