Chain Link?
aener
Hey all,
Just bought a new chain, but I'm a little confused...
I've never had to buy a new chain before so forgive me if it's a stupid question :P ....
But what the hell is this?
IPB Image
A quick response would be handy in this issue as I wanna put it all together now...
Cheers
Flipp
get your chain wrap it around your front sprocket or freewheel and around your rear freehub or sprocket
then to link the two end together use the largest chain part with the two nobles on and put that through each of the holes on either end on the chain
then add the solid chain lump which is flat
and then clip on the littiest part with the gap at one end of the link, you push it on from one end and make it clip at the other
Make sure your chain is on right way round as well
Hope it helps lol, bit sketchy but meh
Will
Edited by will17will17
the closed end of the little fishy shaped clip bit should be going forwards when you're pedalling - like it's swimming along with your chain (thats how my chainbox describes it anyway)
