Heatsink Refills
Dan-Walker
How can you fail :S .I used epoxy glue extra strong.It will have some epoxy resin and epoxy hardener in the pack , you can get some from b&q.Then you have to mix them together , then get an old spoon or sumething and scoop it into the backing.Press your pad in and put it in a vise or anything you can find to clamp it together.Then just leave it for however long it says.
