Dan Jones Posted August 14, 2006 Report Share Posted August 14, 2006 I'm looking for the 4 bolts for the Magura 4 bolt mounts.I found them on this site www.stagonset.co.uk and wasn't sure if they are ok to use as it says:"Presently we offer standard metric fasteners in A2 grade stainless steel, perfect for corrosion resistant applications and ideal for motoring and marine duties. If you are replacing ordinary steel bolts then please be aware that A2 stainless steel has a slightly lower tensile strength than standard 8.8 grade plain carbon steel bolts."Does anyone know if they will be strong enough or alternatively a good place to get the bolts from?ThanksDaniel. Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted August 14, 2006 Report Share Posted August 14, 2006 they will be fine just think, you are most probably going into aluminium (most modern frames), therefore the alu threads will definately go before the stainless bolt Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted August 14, 2006 Report Share Posted August 14, 2006 while where on this topic where the hell can i get the spacers you need to run a booster Quote Link to comment Share on other sites More sharing options...
Janson Posted August 14, 2006 Report Share Posted August 14, 2006 Get an aluminium pipe with outer diameter of 8mm and inner diameter between 5.1 and 6mm and hacksaw some up. Probably cheaper, and you can get the perfect length for your brake set-up (xtr boosters require long spacers when ran with alu backings for example, unless you wanna file the booster).sorted. Quote Link to comment Share on other sites More sharing options...
Egg Fried Rice Posted August 14, 2006 Report Share Posted August 14, 2006 dave85 sells bolts AND booster spacers, he makes them apparentlyJK Quote Link to comment Share on other sites More sharing options...
