rambo Posted August 14, 2006 Report Share Posted August 14, 2006 jojo dose anyone have a experience with the Shadow Conspiracy interlock chain 2 and what do you think of the Shadow Conspiracy interlock chain 2? is it strong enough for 20" trials? thanks, rambo Quote Link to comment Share on other sites More sharing options...
jacks Posted August 14, 2006 Report Share Posted August 14, 2006 its strong enough for everything)on stock you can run it without tensionerbut its a bit heavyand little advice: soak it in kerosene before installing to prevent wedging Quote Link to comment Share on other sites More sharing options...
Krisboats Posted August 14, 2006 Report Share Posted August 14, 2006 Theres one on the desk in front of me.. its a beast.. i havnt used the actual chain, just a single link from it and it looks much stronger than my KMC Kool chain its attached to. the pins bigger, the plates are bigger and it just looks generally more robust. Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 14, 2006 Report Share Posted August 14, 2006 Only thing I didn't like about them was how flappy they are (side to side), the noise they make when in use, and the way they seem to just fall apart when you take them off. I'm running a single V2 link in my 510HX chain, and when I undo the quicklink that joins the chain at the end of the V2 link, the bushing falls out and it goes to shit. Not super confidence inspiring.The more you break the chain the more the pins deform and make it easier for the plates to slip off, so make sure you don't break it very often Quote Link to comment Share on other sites More sharing options...
aaron-i'anson Posted August 14, 2006 Report Share Posted August 14, 2006 Haha i hope they are good just bought krisboats one. Quote Link to comment Share on other sites More sharing options...
