Monty 221 Pr 06 Hub
Fvil
I got a standard spec monty 221 pr 06
and i was wondering about the Front hub
i cant find any details about it
because i was wondering whether to change it to a Hope pro2
or just leave it ????
so really the question is
is the front monty 221pr disk hub anygd?!?!?!
thankyou all
you have it, surley you should know.
If it's not giving you problems don't worry about it. keep in mind that if you do decide to change hub, you'll have to re-build the wheel, and you will most likely need new spoke's too....
yer that should be the case
but i hav no clue
i m sure its a standard monty disk hub
i would take it apart and look
but it ll just give me trouble
i was just temped by the Hope pro 2 because
i found a shop sellin for 13quid :-
thanks
but i hav no clue
thanks
link please....
your front hub will be fine. its a front hub, it doesnt do anything except spin and hold a disc rotor. it ll be fine
That's what I was trying to say too.
indeed, link for that if it's going for £13, i'd say it's a knock off of some sort at that money, and would probobly be worse than your monty hub.
Upgrade/change when you need to.
