An_toin3 Posted August 14, 2006 Report Share Posted August 14, 2006 (edited) So here's the deal, My frame is a yabaa bow and there is a huge tire clearange, I run a DX-32 ! my problem is that when my pads wears, even though my pistons are placed to the maximum, TPA is done at the max too ! my lever is still near my handlebar !There are plenty of pads material left in it !, but because my rim is too narrow for this frame, I have to buy new pads everytime even though they are still good ! the easy way would be to get a wider rim ! already had an echo and I killed it in less than 3weeks ! Try-all.., well it's too expensive for me !Is there any way to make the pads go further ? like adding something to the backing ? I don't know ? need help there Thanks Edited August 14, 2006 by An_toin3 Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted August 14, 2006 Report Share Posted August 14, 2006 So here's the deal, My frame is a yabaa bow and there is a huge tire clearange, I run a DX-32 ! my problem is that when my pads wears, even though my pistons are placed to the maximum, TPA is done at the max too ! my lever is still near my handlebar !There are plenty of pads material left in it !, but because my rim is too narrow for this frame, I have to buy new pads everytime even though they are still good ! the easy way would be to get a wider rim ! already had an echo and I killed it in less than 3weeks ! Try-all.., well it's too expensive for me !Is there any way to make the pads go further ? like adding something to the backing ? I don't know ? need help there Thanks Sorry to say, but if your frame is made for a wide rim, the only solution is to get a wider rim, if not there is no other way of doing it. Try-all rims are only £38 so that is not too bad because i think echo are £35, so there is not much difference, so just get yourself a try-all rim, although they are made of cheese, but hey see how you get on. Dan. Quote Link to comment Share on other sites More sharing options...
JT! Posted August 14, 2006 Report Share Posted August 14, 2006 Quote Link to comment Share on other sites More sharing options...
An_toin3 Posted August 14, 2006 Author Report Share Posted August 14, 2006 (edited) Try-all rims are only £38 so that is not too bad because i think echo are £35Dan.I live in canada, echo rims are 70$ CAD and Try-all are 90$ CAD so that's a huge difference for me ! 90$ ain't that easy to get too.., no job, going to scool doesn't help !What JT! posted seems nice although I don't really know what is the difference between normal brake mounts Could someone enlighten me on that ? Edited August 14, 2006 by An_toin3 Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted August 14, 2006 Report Share Posted August 14, 2006 He wants it so his pads are closer to the rim not further away.Dan. Quote Link to comment Share on other sites More sharing options...
Heatsink Posted August 14, 2006 Report Share Posted August 14, 2006 Turn those Tensile mounts around and it will bring the brake closer There's also the classic "Pad Bodge" which involves attaching an old pad backing onto your current pad using screws. Historically this was used when the first Level Bosses came out with around 100mm spacing between the mounts but everyone still was running narrower rims.Bruiser1 (RomanR on OTN) did the set-up above ^^ Full details: http://www.trials-forum.co.uk/forum/index....mp;hl=pad+bodgeSteve Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted August 14, 2006 Report Share Posted August 14, 2006 You sure you don't need a re-bleed aswell?Mat Quote Link to comment Share on other sites More sharing options...
An_toin3 Posted August 14, 2006 Author Report Share Posted August 14, 2006 Thank you so much Mr Heatsink Gonna try that !And I don't need a re-bleed because If I put new pads in, my magura is working very well ! The tensile mounts seems nice.., where can you buy those ? I checked Tartybikes ans Selectbikes, none of them ! if the "pads bodge" doesn't work ! I might try that.. Quote Link to comment Share on other sites More sharing options...
JT! Posted August 14, 2006 Report Share Posted August 14, 2006 (edited) He wants it so his pads are closer to the rim not further away.You turn them upside down you twasck. They will be on tartybikes soon enough, but if you want them now phone supercycles.Selectbikes don't trade with Onza.They're off-set so the maguras can be made closer to the rim, or further away. Edited August 14, 2006 by JT! Quote Link to comment Share on other sites More sharing options...
Guest Posted August 14, 2006 Report Share Posted August 14, 2006 Sorry to say, but if your frame is made for a wide rim, the only solution is to get a wider rim, if not there is no other way of doing it. Try-all rims are only £38 so that is not too bad because i think echo are £35, so there is not much difference, so just get yourself a try-all rim, although they are made of cheese, but hey see how you get on. Dan.Excellent advice, good one. Quote Link to comment Share on other sites More sharing options...
