baz123 Posted August 13, 2006 Report Share Posted August 13, 2006 hi. i am currently learning how to ride with one finger on the brake but i just cant find a convertable place to ride with, all my fellow riders have told me i should ride with one finger as i get more control over the bike. but i just cant get used to it..it would be very nice for some tips on how to set them up thanks for your time. Quote Link to comment Share on other sites More sharing options...
rids Posted August 13, 2006 Report Share Posted August 13, 2006 hi. i am currently learning how to ride with one finger on the brake but i just cant find a convertable place to ride with, all my fellow riders have told me i should ride with one finger as i get more control over the bike. but i just cant get used to it..it would be very nice for some tips on how to set them up thanks for your time. i ride with my brakes about 2" away from the grip so i can only grab them with 1 or 2 fingers and i have them ajusted so they don't open up fully Quote Link to comment Share on other sites More sharing options...
RLC Posted August 13, 2006 Report Share Posted August 13, 2006 put your hands on your grips then point your finger out towards the brakes, then moves the brakes along so only your one finger can reach the tip.Should work, thats how i set mine up Quote Link to comment Share on other sites More sharing options...
GAZ T Posted August 13, 2006 Report Share Posted August 13, 2006 if you don't find it comfortable to use one finger then don't, if your doing ok with 2 on the lever than whos to tell you different that its wrong or whatever they say about using 2 if that makes senseor if you really want to use 1 then loosen the lever place your hand in the usual place on the grip then slide the lever along until you finger sits in the little groove on the blade.......hope you can understand that!hope i've helped ......GAZ...... Quote Link to comment Share on other sites More sharing options...
trials_mad Posted August 13, 2006 Report Share Posted August 13, 2006 It is better to use 1 finger braking as you do get more control over the bike. Also when you are on your back wheel you need to angle the levers so they are straight out for your fingers to grab and that they are not angled so it feels unatural. Again when you are putting the levers on the bars i usually have mine about 1inch away from the end of the grips (depends on the size of your hands) and the lever out so i can just grip it with the end of my finger. This way you maximise the ammount of control you have within your hands.Hope this helps Quote Link to comment Share on other sites More sharing options...
dan more Posted August 13, 2006 Report Share Posted August 13, 2006 tape all your fingers together and ride about and try different tricks like that start off with simple things then ull get use to it and start doing bigger things. dan Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted August 13, 2006 Report Share Posted August 13, 2006 Lose the leaverTake hold of the bars as if you were to rideNow hold out the finger next to your thumb as if you were to use your brake one fingeredNow move the leaver in till it feels rightSet leaver at an angle of 45 ish degree and where it feel right on the one fingerRepate for you right or left finger pending what order you did it inNow go ride and make any tiny adjusment you need toYour finger will hurt a bit as they work little hard but it feel better and everythingIf you want to get over the pain feeling if you have any, it's a work out for you finger to use for fingering! Quote Link to comment Share on other sites More sharing options...
baz123 Posted August 14, 2006 Author Report Share Posted August 14, 2006 thanks i will try all these ideas out:D thanks for your time Quote Link to comment Share on other sites More sharing options...
baz123 Posted August 18, 2006 Author Report Share Posted August 18, 2006 thanks i will try all these ideas out:D thanks for your timeBUMP Quote Link to comment Share on other sites More sharing options...
padarik Posted August 18, 2006 Report Share Posted August 18, 2006 why did u just bump this topic? Quote Link to comment Share on other sites More sharing options...
BinaryWizard Posted August 19, 2006 Report Share Posted August 19, 2006 Can anyone actually pedal kick good with 2 fingers ? i found it rather hard! Quote Link to comment Share on other sites More sharing options...
JT! Posted August 19, 2006 Report Share Posted August 19, 2006 if you don't find it comfortable to use one finger then don't, if your doing ok with 2 on the lever than whos to tell you different that its wrong or whatever they say about using 2 if that makes senseBut it is better to brake with your pointing finger.There's no real trick for setting up your leaver position. Basicly trial (haha) and error. Just keep fiddling till you get it right.It does take some getting use to though, but if you stick at it for a few rides, you'll wonder how you managed with 2 fingers.You do need a somewhat powerful brake though, make sure your running aftermarket pads, no koolstops or standard black pads. Quote Link to comment Share on other sites More sharing options...
