Hicksy Posted August 13, 2006 Report Share Posted August 13, 2006 can someone mayb tell us how u could get rounded bolts out!? please Quote Link to comment Share on other sites More sharing options...
watto Posted August 13, 2006 Report Share Posted August 13, 2006 Where abouts are the bolts , what type of bolt are they ? Quote Link to comment Share on other sites More sharing options...
Hicksy Posted August 13, 2006 Author Report Share Posted August 13, 2006 (edited) Where abouts are the bolts , what type of bolt are they ?well they are the stem bolts but they are screw driver bolts my m8 is a bogjer we have tryed lots of ways which still dont work so we thought of useing a grinder cant think of another way Edited August 13, 2006 by Hicksy Quote Link to comment Share on other sites More sharing options...
watto Posted August 13, 2006 Report Share Posted August 13, 2006 Get a 4mm or 5mm drill peice and drill through the center of the bolts should come out as the drill goes through, or you could get a hacksaw in the gap of your stem and cut the bolts then they should just screw out . Quote Link to comment Share on other sites More sharing options...
Tom_ Posted August 13, 2006 Report Share Posted August 13, 2006 (edited) Try getting a hacksaw cutting a groove into each bolt, then put a screw driver in at an angle towards one end of the groove. Now smash it round with a hammer. this is what i did when i rounded the bolt on my chain tensioner and it worked a treat. tom Edited August 13, 2006 by tom132 Quote Link to comment Share on other sites More sharing options...
rids Posted August 13, 2006 Report Share Posted August 13, 2006 can someone mayb tell us how u could get rounded bolts out!? please there are a few ways to remove bolts but don't grind the top off as it will make it harder.1 u can use a center punch to tap round the bold (long winded but dose work be patiant with it)2 drill a small hole in it and buy a pack of easy outs 3 if its a x head get a pack of jml screw removers they work really well4 drill it out totally but mind the threads5 heat up the part u want to remove from making the metal expand 6 if its rusted in use cilit bang on the bolt (cover frame with plastic bag)and leave over nightthere maybe other ways but with out seeing what i'm dealing with its hard to guess can u post pic ? Quote Link to comment Share on other sites More sharing options...
lucas189 Posted August 13, 2006 Report Share Posted August 13, 2006 will get some pics 4 u as soon as Quote Link to comment Share on other sites More sharing options...
trials_mad Posted August 13, 2006 Report Share Posted August 13, 2006 can someone mayb tell us how u could get rounded bolts out!? please I have rounded many bolts of before and i have found a way to get them out. Basically just take a pair of strong mole grips or pipe grips if you have them and just tighten them and twist them just as you would with an allen key etc. If you grip the head of the bolt tight enough and twist then it will come out with ease. I would also recommend that if you tend to keep rounding more bolts of then buy a good ratchet, with adaptor, with an extension bar and this gives you more leverage and you tend not to round bolts of as much as you would with an allen key.Hope this helps Quote Link to comment Share on other sites More sharing options...
