aaron new zealand Posted August 13, 2006 Report Share Posted August 13, 2006 I'm wanting to get some monty isis cranks for my mod but are wanting to know if there is enough space to run a freewheel and echo bashring. Is any one out there running this set up ? How much thread space do you need to safely run this set up ? Any help would be great Quote Link to comment Share on other sites More sharing options...
bhups Posted August 13, 2006 Report Share Posted August 13, 2006 Dont get monty cranks there known for snapping. Quote Link to comment Share on other sites More sharing options...
sunn_bmixx Posted August 13, 2006 Report Share Posted August 13, 2006 i dont have a problem with them i have riden with them and so have my friends for well over a year now and one of my frends has broken one and that was a manufacure fault and was under guarentee.get them Ian Quote Link to comment Share on other sites More sharing options...
RLC Posted August 13, 2006 Report Share Posted August 13, 2006 How bout some tensiles or some adamants Quote Link to comment Share on other sites More sharing options...
aaron new zealand Posted August 14, 2006 Author Report Share Posted August 14, 2006 Are running square taper monty cranks at moment and had no problem, nor have my friends. We have limited stuff available here. Trials are fairly small scene here and are fairly loyal to monty importer but he isn't very clued up so wanting to know if this set up works or how much thread space is required for it to work safely ? Quote Link to comment Share on other sites More sharing options...
matt! Posted August 14, 2006 Report Share Posted August 14, 2006 Dont get monty cranks there known for snapping.this is a true comment, but yea i think there will be enoguh roooom. Quote Link to comment Share on other sites More sharing options...
Synergy Posted August 14, 2006 Report Share Posted August 14, 2006 best bets are get some zoo cranks or some echo forged cranks. there will be enough room for a bash ring and freewheel on them but make sure your bb is long enough they are meant to be 127.5 or 128mm but jt said he ran a smaller one and it was fine(must have been black magic or something ) Quote Link to comment Share on other sites More sharing options...
aaron new zealand Posted August 14, 2006 Author Report Share Posted August 14, 2006 Cheers was wondering what length bb would be required. Any ideas what the measurement is for amount of thread on zoo / echo cranks ? If it works with them and they have same length threaded then guess should work with monty too. Quote Link to comment Share on other sites More sharing options...
Synergy Posted August 14, 2006 Report Share Posted August 14, 2006 Cheers was wondering what length bb would be required. Any ideas what the measurement is for amount of thread on zoo / echo cranks ? If it works with them and they have same length threaded then guess should work with monty too.well i ran echo cranks before fine with a freewheel and bashring, best thing to do would be email tarty bikes? or speak to daniel ko (trials-uk.com) Quote Link to comment Share on other sites More sharing options...
aaron new zealand Posted August 14, 2006 Author Report Share Posted August 14, 2006 Will do. Really liked the look of echo and zoo cranks but aren't they only 170mm in length ie only for 26" Whats the go with echo's external bb's. Are the echo isis cranks designed for this or normal isis bb's or both ? Quote Link to comment Share on other sites More sharing options...
ogre Posted August 14, 2006 Report Share Posted August 14, 2006 Will do. Really liked the look of echo and zoo cranks but aren't they only 170mm in length ie only for 26" Whats the go with echo's external bb's. Are the echo isis cranks designed for this or normal isis bb's or both ?The external bbs will not take a front freewheel, you'll need a normal isis bb for ffw, and 170mm cranks are amazing on mods they give you more leverage (not loads, but more than shorter cranks) which should make gapping etc easier Quote Link to comment Share on other sites More sharing options...
