Headset
RLC
I was wondering if any of use know,how stan shaw n them can have a king headset (1 and 1/8th)
in a onza limey :huh: what do they put in there headsets to make it fit? and where could i buy one from....also would this work on a monty 221 ti 07 :huh:
Info please
If you are having problems fitting it in your frame,
too tight? no, thats how its supposed to be, use a headset press.
Too loose? either your head tube is ovalized of slightly oversized. Chris king makes 2 1 1/8 sizes, Accurate and oversized.
Or your head tube might be 1 1/4 they make that too.
Integrated? Chris king does make an integrated headset, but you have to use a special tool to get the head tube to the right size.
or were you having a problmem with the headset at all and just asking a question?
Edited by justfuzzit
So is that stainless steel ring stuck in the headtube or can you take it out?
Can you buy one from tartybikes? No dont think a can (i have just looked)
And what size headset is a monty 221 ti 06 and 07
Edited by RLC
I was fancy a monty 221 ti 06 or 07 and was wondering if a what size headsets they are? Because i have a chris king headset i want to use.
