Best Pads For A Smooth Rim
trials_noob
dont do any of that, get your self a grinder, its soo easy its unbelivable. Take off your tyre and inner tube. Then go around the wheel keeping the grinder at a right angle to the rim. Then kneel on the rim at the bottom and work you way around the rim making a light mark, then go around again untill you have a good grind, just dont good too deep. Then get some koxx bloxx or you can have a good brake just on cool stops. My friend runs cool stops with good grind and has no problems. I would recomend this first ( AND WEAR GOGGLES) Otherwise i can advise plazmatic yellow pads on a smooth rim. Matt staples is riding with them on his new bike at the moment on a smooth rim and the grip is amazing!
Hope this helps buddy
p.s. and i wouldn't advise tar this is just an easy way out of getting a good brake, doesn't last long and is not good in the rain. To do it properly grind, as this will pay off in the long run after taking off and putting on new tar.
Thanks
Ian
Edited by sunn_bmixx
yea man, i would seriously advise doing a grind, once you have done it, you will think it is well easy, cause it is!! just do it then you never have to worry about it, and pay for some deasent pads i am running koxx browns and i think its perfect, remmber to set your brake up good though and not to have any rub :D
Ian
depends on the pads and the rim + plus the deepness of the grind. it would be best to check the other topics on this instead of asking the same questions again. dont mean any offence
cheers padarik
Edited by padarik
