Stripping Crank Arms....................................
Sucram
the cranks are powdercoatead because i used to own some, the best thing to strip them is nitromours (you can buy this from b and Q etc...) just apply it leave it for about 5 minute then then scrap of the goo substance with a thin metal object shud come straight of. the instrutions should be more clear on the back of the tin...
hope i helped matt!
nitromors is shit use caustic soda ive just done my cranks and all u do is put some soda in some warter and then put ur cranks in it and then leave it until the warter goes the colour of ur cranks then take them out and rinse with sum warter non of tht scrap it off stuff
nitromous is good for powdercoat, lmao caustic soda dosent work on powdercoated stuff :P
matt (Y)
Edited by matt!
There are loads of diffrent ways such as:sand paper, nitro morse,coustic soda,air drill with a sand grinder,sander,sand blaster,glass blaster,there all diffrent ways ov doin it the easyest 1 is sand paper but that will take the longest but if you do it right it will give a good effect,unless you can find a person with a sand blaster that will take like 5 mins to do,but even better if you can find a shop with a glass blaster do that it takes as long as the sand blaster but it comes out with a more finer finish and you will be able to get a better finish when you laqure them! (Y) But theres always the option ov nitro morse witch you can bye from your local d.i.y store it takes a bit but it does the job! (Y)
i hoped that made any sense lol,and i hoped i helped! (Y)
danny...
Edited by Danny Swindlehurst
