A Few Questions Abuot The Mbk T1000 Frame
Oskar
Hello, I'm thinking of buying one when I have the $ :)
Just A few questions here...
Will a 118mm FSA ISIS bottombracket with Middleburn cranks and 20t sproket fit the frame? If not, how wide will the axel be to fit?
Right now i ride with a 110mm and 5 degree Thomson stem and tryall yourself replica 25.4 bar with a 20mm spacer under, will that be to low for the MBK?
On my Ilions my tire rubbs on the frame, I have a 2.4 Schwable Big Betty on a DX32, will the MBK have more tireclearence?
How stiff is the frame? And will it need a brakebooster? And how does it ride?
And last but not least, will it be stupid to go from a 1035mm WB and 0mm BB rise frame to a real UCI frame?
Cheers!
Edited by Oskar
Hey dude, i was thinking about getting one myself actually. Your bb might not fit as the frame will probably take a wider one, itd probably be best giving tarty a ring and asking them which one would be best for you!
As for your bars and stem setup, they should be fine, when you get the frame try and play around with it to get it riding just how you like it.
The MBK will have more tyre clearence then your frame at the moment so that wont be a problem.
Im not sure on any of the rest because i dont own one and have never ridden one but i know that you'll be fine adjusting to it.
Hope ive helped. (Y)
Si.
