Which Adaptor For A 203mm Rotor
Barbra
a quick one... I'm going to be buying a 203mm rotor for my bike, because ive just bent mine, should i just use a +40mm adaptor or is there such a thing as a +43mm adaptor :S
Just figured i'd ask before pi$$ing my money away if anythings wrong.
As far as I know there is no +43mm adaptor. Just check your current brake setup... if there is at least 1,5mm clearance between rotor and caliper, a 40mm adaptor will be fine. The pads won't completely cover the rotor though... but that's ok. I used to ride a 190mm rotor with a 185mm caliper and it was fine.
ah ok cool mate (Y) cheers for that.
