Home Made Pads?
onzatprodude
hey, has anyone tried making there own pads?
if they were any good....
what 'ingriediants' did you use?
and how do you put them together?
and how do you get them the shape of the pad backings?
also any one like heatsink or iolo ect that dont want me to know there secret just give me some tips
thank you
yer probablys easyier but if i had/made a great sort of pad that suit me down to a tea that would be great as it would save me alot of money in the long run, and will be quicker as i wouldnt have to wait for them to be sent.
plus if there beast i could sell some and make some money myself.... unless thats braking rules or the law :Slol, well then ill just keep them myself
ok so its just types of rubber. but do i try and melt it or something to go into the right shape.
remember guys this will be my first time and i need all info on how to do it please
no just cut it up, dont heat it up, you ll wreck it. itll burn and go hard
Just cut it into the shape of the backing, and glue it in, it's probs not going to be that good first time, so it doesn't really matter if it's not the best of jobs, remember to try and find a harder compound for grinds, because soft rubber will just dissapear, e.g... Shoe's or summeeeeet' :blink: .
Mat
Home made pads can be brilliant, but you should remember that the ones bought from a shop are not first generation - they have been prototyped and tested non stop.
Heatsink and rim jam both set out as guys making home made pads, who eventually wanted to offer them to the public. Adam Read also went through a fase of working on some pads (tarty pads) but nothing came of it because it was too time consuming. Also it was often the case that when they made a promising break through, something else came along as an issue. Basically making home made pads you have to be lucky to find a good material first time.
If you try it good luck to you, and keep us posted as to how you do.
polyurethane is good, so is polybutamene (sp)
find a local buisness that deals with the two types and ask/buy some in different durometers and test them.
I have bought about 7 different compounds from my supplier, two seem good.
