Dipping And Spraying.
Danny Kearns
Dipped?
Just spray it yourself, go to halfords, don't they do some 3 for 2 on there paint range? Pick up a primer (depending n the colour of your top coat pick a suitable primer, that is if halfords stock the varieties) Get your colour, and a clear laquer.
Lightly sand the frame, 1 coat of primer, don't go mad just yet. A really nice thin coat, wait until its dry, sand it lightly again, next coat and repeat this about 4 times. Wait until the primers dry/hard then sand slightly and put your top coat on. Again lightly sanding inbetween coats. Usually 4-5 coats is plenty. After your 3rd coat (if your doing 5 coats) stop sanding inbetween coats, and just apply the paint.
Then laquer, 2-3 coats of this using the same method as your paint. With no sanding.
Apply the paint in a stroke, about 20 cm's away from the frame, from left to right. Don't spray in blobs where you've missed a section just spray across it a few times (Y)
Tom
